Toshiba A300 - Tokin cap exchanged.
  • PCManiac
    • Sep 2012
    • 28
    • Str
    Greetings guys,
    I got two toshiba A300 that were somewhat dead..
    Changed both of their nec/tokin cap for 330 tantalum and they are working.
    Altho, I would like to ask if some one has the boardview file of their board or if some one knows where can I buy it.
    What they are doing from time to time, and I suspect is a charger fault, they turn the green light on. I press the button to turn the laptop on and it dies. The fan flickers and loses power.
    I measured on the charger pins (the four pins, 2 red and 2 black) after the barrel plug and before turning it on I get a steady 19v on them. When I press the button, the voltage drops to around 11.5v and then raises back up when the mobo dies (I can listen some click when it cuts the source).
    Am trying to understand for sure where the problem lies so I can tell the owner, if it needs more things or just the power brick.
    Already redid the tantalum solders.
    The board is a PT10G_6050A2171501_MB_A03. I fould some schematics for it but can't seem to find the boardview nor be sure they are the ones for my model since I don't know where to find the things..
    Would appreciate your help even if only with suggestions.
    Thank you.
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: Toshiba A300 - Tokin cap exchanged.
    I think this 330uf is not enough, because you have to install 4 caps but your photo say you just soldered only 3. add more caps and clean the motherboard soldered place. This problem is only with capacitors.
    • String2016
      • Nov 2015
      • 2230
      • philippines
      Just put 4 to 5 tantalum caps
      • dmartins
        David M
        • Apr 2014
        • 197
        • Lisbon
        Carissimo , mete 4x 330uF e fica Ok !
        Cumprimentos
        I was saying to this guy in our language to install 4x 330uf tantalum caps
        • PCManiac
          • Sep 2012
          • 28
          • Str
          Thank you all for your suggestions.
          Will do so!
          I have read in other forums that 3 were enough and, to be honest, that's all I had laying around. Have to get another dead laptop donor board for those haha.
          Thank you/ Obrigado.
          • PCManiac
            • Sep 2012
            • 28
            • Str
            Greetings,
            I have added the fourth cap and, still the same.. :\
            any other suggestions?
            • shuc
              • 30
              • Romania
              This is what I do... and works fine.
              • gabiz_ro
                • Mar 2011
                • 167
                • Romania
                Test with another good working charger.
                Where you here click when it cuts the source? Motherboard or charger?
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3578
                  • slovakia
                  caps fault is that laptop restarts in LOAD
                  u have short in some powerswitched rails.
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    I had a problem something like that in an A200. I found a shorted High Side MOSFET in the CPU VCORE regulator.
                    • PCManiac
                      • Sep 2012
                      • 28
                      • Str
                      Thank you all for your input.
                      Shuc - At first I tried that, unfortunately I wasn't able to do it so read some where in the forum that the center was negative as well and I could scrape the insulation off it.
                      Gabiz_ro - I listen the click on the motherboard side.
                      ktmmotocross - it has been running under load for the last 4/5 hours with no reboot. Still think it's a power source issue.. gotta try to get one to test.
                      rievax_64 - Mind trying to explain me which ones are the vcore mosfet? Gotta google how to test *fets later on.
                      Thank you all.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3578
                        • slovakia
                        Thank you all.
                        thats what i wrote. u dont have problem with tokin cap.
                        check resistance of all big coils on board. u have short somewhere
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          Q17 and Q18 are the high side MOSFETs.
                          • PCManiac
                            • Sep 2012
                            • 28
                            • Str
                            Thank you guys.
                            ktmmotocross: Which ones are those coils you talk about and how to measure them?
                            rievax_60: checked those with no shorts found. Took the time to test 12 and 21 as well as I was at it since some one said in another post that those could be troubles as well...
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3578
                              • slovakia
                              check its resistance to ground and all big grey coils
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                Thank you guys.
                                With the high side MOSFETs, check carefully for Drain to Gate leakage.
                                The low side MOSFETs can not be checked in circuit unless the CPU is removed. I have never seen low side MOSFETs fail anyway.
                                • gabiz_ro
                                  • Mar 2011
                                  • 167
                                  • Romania
                                  From what I understand,laptop works fine,only sometimes when you hit power button,laptop start-up,fan also,voltage from charger drops from 19V to ~11.5V,board make a click noise and shut down,voltage from charger rise back to 19V
                                  Checking boards for shorts have low rate of success since most time laptop power up and work fine,so you'll not find any short.
                                  In event of short on some power rails,you must be lucky to find it since is not permanent,appears only some times in some conditions.
                                  You may try to monitor all power rails in same time and see which one cause this.
                                  • PCManiac
                                    • Sep 2012
                                    • 28
                                    • Str
                                    I will keep this on hold till I get my tantalum caps and solder them to make sure am not missing anything.
                                    Thank you all
                                    • PCManiac
                                      • Sep 2012
                                      • 28
                                      • Str
                                      Hey guys, just a quick update on this.
                                      These two laptops were fixed successfully after I got my tantalum and are working as happy ever since then.
                                      One of them had as well a bad PSU, which was what was causing the sudden shutdowns and not powering on.
                                      Thank you for your help.
                                      Thank you all
                                        Toshiba Satellite A300-1RZ Specification for Upgrade or Repair
                                        This specification for the Toshiba Satellite A300-1RZ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1RZ boardview and A300-1RZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Satellite...
                                        09-06-2024, 05:27 AM
                                        Toshiba Satellite Pro A300-22J Specification for Upgrade or Repair
                                        This specification for the Toshiba Satellite Pro A300-22J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-22J boardview and A300-22J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                        Toshiba Satellite Pro A300-1MK Specification for Upgrade or Repair
                                        This specification for the Toshiba Satellite Pro A300-1MK can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1MK boardview and A300-1MK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                        Toshiba Satellite A300 A300-14S Laptop Schematic
                                        Quanta BL5S Santa Rosa - Rev 1A...
                                        11-01-2024, 07:49 AM
