how to check dead laptop motherboard step by step
  • cdwayne foremost
    • Mar 2015
    • 20
    • jamaica
    how to check dead laptop motherboard ,leave a comment pls
    https://youtu.be/0k-Q8bIAS7o
  • Me.Orouji
    • Dec 2015
    • 117
    • Iran
    Re: how to check dead laptop motherboard step by step
    Good job
    • koby058
      • Jan 2017
      • 375
      • israel
      thank you very much, this is very importent and high quality video.
      we will be glad if you can do more video.and more basic
      T H A N K S!
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        Good video for repair old motherboard, unfortunately new ones are a bit more complicated
        • rafik_40150
          • Dec 2016
          • 22
          • algeria
          thank you so much for the video and the quality i hope that we ll see other videos by you or or brothers here
          thank you soo much for the great work
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            tnx, nice for biginers like me
            Im Back... sort of...
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              This is not bad. It good be improved by having the step by step procedure written down so it could be downloaded in any languish and the student could follow step by step as you were doing it on video.
              • Acnologia
                Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                by Acnologia
                Here is a pretty crazy one.
                Step 1.
                Laptop was brought to me as dead not working. Removed everything , cleared everything.
                Step 2.
                Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                Step 3.
                Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                Step 4.
                Lets ,dive into the board. I see the edp cable on the...
                05-07-2025, 07:16 AM
              • thumper69
                Alienware M17x Laptop motherboard may be dead
                by thumper69
                We use a laptop to connect to an omron CPM2A serial port for programming and data transfer. Using a usb to serial adaptor and a blackbox connecting cable. The operator of the equipment had a failed ac power plug that powers the plc and changed it reversing the hot and neutral lines. the result was when connecting the plc to laptop it blew out adapter, plc, and laptop. apparently it sent 115 volt ac via ground into usb port of laptop. Laptop appears to try and power up but shuts down after a few seconds. Any repair possible or do i need new motherboard.
                09-03-2023, 06:41 AM
              • tk3000
                Dead Laptop Motherboard, then refurbished one installed...
                by tk3000
                My venerable and old laptop (Toshiba Satellite P75-A7200 equipped with an i7-4700MQ, circa 2014) and previously a powerful machine during its heyday is no more. Have been using it for many years, but about 3 months ago it went kaputt for no apparent reason (left it on overnight [normally it goes to standby mode after some idle time], and in the morning it was cold dead with no boot, no post, no leds; nothing at all).
                Since the 1990s I have been building custom desktop computers, etc; but it has been few years since my last built one and for the last 15 years I have built very few...
                08-20-2022, 08:45 AM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • jamesp
                Lenovo laptop dead motherboard GS752 NM-C781rev. 1.0 2019-11-25 inscribed at the pcb,
                by jamesp
                I have a dead laptop with mainboard model GS452/552/752 nm-c781 rev 1.0, i have initiated troubleshooting with the use of digital multimeter. checked voltage signals up to PM_SLP_S3#, found out that before PM_SLP_S3# signal , a PBTN_OUT#_R signal has 3.2 volt state and after pressing power on, PBTN_OUT#, It drops to logic level zero for around 12 secs and then back again to 3.2v for 6 secs. it will loop like that until you pulled out the adapter power. during loop the PM_SLP_S3 and S4 SIGNAL has no output. (0 volt ) may i ask for help to anyone with this kind of board and same kind of problem....
                03-18-2024, 08:17 AM
