Toshiba Satellite A205 Strange Battery Issue
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey guys, I have a Toshiba Satellite A205 that is giving me some strange battery issues. Less than a year ago, I bought a brand new 9 cell battery from amazon. I believe it was an Anker battery but do not remember for sure. It had plenty of positive reviews so it seemed like a legit product. The battery has worked great for about 8 months but now it is giving me issues. I am not sure if the problem is in the battery or the laptop.
    I can charge the laptop with it on or off and it seems to charge normally. The orange battery light will change to blue and the battery meter in XP will show 100% battery. The problem is the battery will run down normally until around the mid 80's and then it will drop to about 4%. I then plug the laptop in and the battery will sit at the same percentage for a very long time. Sometimes the percentage even goes down a bit. If I leave it for a while and come back it will say fully charged again.
    I have tried steps I've read on the internet to re-calibrate the battery by letting it die completely and then charging it fully without turning the laptop on. This hasn't fixed anything and it is still showing the same problems.
    Any ideas whether the problem is a calibration issue or the battery itself?
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Toshiba Satellite A205 Strange Battery Issue
    I think you did not exercise your new battery sufficiently...
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      Hm? From what I understand you do not need to let lithium ion batteries fully discharge before charging them like you do with nimh batteries. Or are you referring to something else?
      canadaboy25
      • mkdj
        ASUS X571 no power : battery issue?
        by mkdj
        Mark and model: ASUS X571
        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
        Tests already made:
        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
        - I have removed...
        07-14-2025, 09:16 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • code share
        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
        by code share
        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
        Here's what I've tried so far:
        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
        • Booted successfully on AC power only with the battery disconnected
        • Visual inspection of the battery — no swelling, burn marks, or connector damage
        • Battery
        04-21-2025, 12:50 PM
      • huzo
        HP ELITE X2 1013 G3 weird battery issue
        by huzo
        Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
        01-31-2025, 12:09 AM
      • danielsak
        Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
        by danielsak
        Hello, I have issue with Dell Inspiron 3542.
        Motherboard marking:
        Code:
        PWB FX3MC REV: A00
        The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
        1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
        1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
        10-11-2024, 04:36 PM
