Toshiba satelite c650 not working
  • FastEddy
    • Jan 2017
    • 9
    • United Kingdom
    Hi guys and dolls,
    For a friend I am trying to find the fault on C650, 6050A2355301-MB-A03, MAS10M.
    I am using the schematic attached.
    Measurements as follows,
    Adaptor only no Battery on
    NOTHING WORKING NO LIGHTS NO FAN COMPLETELY DEAD.
    Battery pins =
    1=0v
    2=0v
    3=0v
    4=0v
    5=1.02v
    6=0v
    7=0.01v
    8=3.53v
    9=3.53v
    CN6000 = 19v
    R6036 = 0v~0.02v
    R6013 = 1.66v ~ 0v
    R6016 = 18.8v ~ 0.00v
    R6000 = 8.53v ~ 8.53v
    L6000 = 3.52v ~ 3.48v
    L6001 = 19v ~ 19v
    FUSE6000 = 19v ~ 19v
    FUSE6100 = 3.53v ~ 3.52v
    D6000= 1.66v - 3.85v - 3.50v
    D6001 = 0.01v - 5.37v - 5.54v
    D6002 = 5.43v - 5.43v - 8.54v
    Q6004 = 5.33 - 0v - 0v
    U6000 =
    1 = 0v
    2 = 0v
    3 = 18.88v
    4 = 5.49v
    5 = 0.07v
    6 = 1.07v
    7 = 8.54v
    8 = 3.48v
    9 = 3.65v
    10 = 5.45v
    11 = 3.51v
    12 = 3.51v
    13 = 3.51v
    14 = 0v
    15 = 3.51v
    16 = 3.51v
    17 = 0v
    18 = 0.01v
    19 = 1.66v
    20 = 5.35v
    21 = 4.09v
    22 = 5.40v
    23 = 0v
    23 = 0v
    U6200 =
    8 = 3.2v
    15 = 0v
    16 = 3.52v
    17 = 3.52v
    Hope above info can help, I think the problem is staring me in the face but I am not skilled enough to figure it out yet.
  • FastEddy
    • Jan 2017
    • 9
    • United Kingdom
    Re: Toshiba satelite c650 not working
    Does anybody have any ideas for this problem?
    • cyberhack
      • Feb 2013
      • 466
      • Uk
      The toshiba is fast asleep, remove battery cmos press power button for 30 sec
      then plug in the brick that should do it power up
      • rievax_60
        • May 2012
        • 897
        • australia
        What voltage is +VBAT?
        • FastEddy
          • Jan 2017
          • 9
          • United Kingdom
          Thanks for reply, the Voltage at +VBat = 3.51v
          • FastEddy
            • Jan 2017
            • 9
            • United Kingdom
            Tried the 30 sec PW button no change
            • smali
              • Sep 2014
              • 287
              • Pakistan
              Try to flash bios.
              • meritosari
                • Oct 2010
                • 774
                • Indonesia
                Might be this case similar with old thread, you can learn it.
                Pin 10 (ACOK) must be low, indicate ac adapter present.
                According datasheet:
                "AC Detect Output. This open-drain output is high impedance when ACIN is lower than 1.485V.
                The ACOK output remains high when the MAX17435/MAX17535 are powered down. For a typical
                application, use a 10k ohm pullup resistor to LDO (pin 4)".
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  As far as I can tell, all of the conditions are right for ACOK to be low.
                  • FastEddy
                    • Jan 2017
                    • 9
                    • United Kingdom
                    Spent the day getting more voltage measurements and putting them onto the schematic.
                    This might give you more insight into the problem.
                    It is only the first 4 pages of schematic but more to follow later.
                    Hope you can see the problem
                    thanks
                    FastEddy
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      Here measurement of MAX normal condition.
                      Acok must be 0V, then
                      PDSL appear be 25V
                      First Check Q6002 and Q6005 (resistance D-S-G)
                      Second, Possibly the IC MAX has failed to work.
                      Third, make sure VBAT have no short to ground.
                      • FastEddy
                        • Jan 2017
                        • 9
                        • United Kingdom
                        There is definitely low voltages in places to what there should be with highest only of 18v. I need to find out why I am not getting the 20+ volts especially at PDSL which is showing 0v. Also Acok is 5.29v and should be 0v
                        • inflex
                          • Aug 2012
                          • 544
                          You might want to be checking / looking for a short. In particular look at the 0805 ceramic caps around the switch mode regulators. Look at the surface of the caps very carefully and don't be surprised if you see some cracks on one.
                          Put your multimeter in to diode mode and start checking the values, should be 0.3V or higher usually, if you get anything like 0.01 then you've got a short most likely.
                          It's a fairly easy way to spend half an hour under the magnifying glass in good light, but it often reveals faults without having to do much else.
                          https://www.youtube.com/watch?v=ZtFH1gn25h0
                          YouTube Repair Videos - https://www.youtube.com/user/19PLD73
                          FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
                            Toshiba Satellite C650-101 C650-15C C650-126 6050A2368301-MB-A02 Laptop Schematic
                            MANAUS 10MD2 MAS10MD2...
                            11-01-2024, 03:13 AM
                            09-06-2024, 05:27 AM
                            09-06-2024, 05:59 AM
