Cq56 no power
  • nixi22
    • May 2016
    • 44
    • Croatia
    Cq56 no power
    Cq 56 wont turn on i got no rsm rst signal while bios chip is on board when i remove it rsm is 1,5v and droping,5v and 3,3v ok kbc replaced same results.Can defected bios cause this problem waiting new programmer to came so i cant flash right now.
  • nixi22
    • May 2016
    • 44
    • Croatia
    Re: Cq56 no power
    Solved, replaced with new kbc,machine turns on all good. Turns out that ebay kbc was DOA.
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • bcstedt
      LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
      by bcstedt
      LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
      Problem:
      On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
      It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
      01-18-2024, 01:03 PM
      03-31-2024, 02:12 PM
    • MicroSMD Lab
      MSI MS-16W1 no power, EC replaced by other.
      by MicroSMD Lab
      Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
      03-27-2025, 07:35 AM
