Weird issue with Samsung NP500P4C-T03CL
  • MCardona81
    • Oct 2016
    • 11
    • Colombia
    Hello
    I have a strange issue with this laptop:
    Procesador: Intel Core i5 3210M (2500 MHz - 3100 MHz)
    RAM: 8GB DDR3 (1600 MHz)
    Video Cards: Intel HD Graphics 4000 (Integrada) NVIDIA GeForce GT 650M (DDR3) (1GB)
    It stopped working for no reason, it turned on, I could hear the cpu fan but It got no image , so i took it to a tech store and the guy manage to "fix it". It now turns on but it shuts down after 45 minutes with no warning and not by overheating, the tech guy has no idea why. I checked the charger with a multimeter and the voltage output is correct. Any help would be apreciated.
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: Weird issue with Samsung NP500P4C-T03CL
    suspect gt 650m
    sigpic
    • MCardona81
      • Oct 2016
      • 11
      • Colombia
      Originally posted by samanthban
      suspect gt 650m
      Is there a way to make sure it's the GPU?
      • MCardona81
        • Oct 2016
        • 11
        • Colombia
        suspect gt 650m
        Current GPU temp its 46°, and the laptops always shuts down at 29:5x min
        • piernov
          • Jan 2016
          • 4439
          • France
          BIOS ME region issue, needs to be cleaned.
          • MCardona81
            • Oct 2016
            • 11
            • Colombia
            How can I do that?
            Complete noob about this
            • samanthban
              • Feb 2014
              • 253
              • Sri lanka
              Give you bios backup, will fix your ME region . post your board number and chipset
              sigpic
              • MCardona81
                • Oct 2016
                • 11
                • Colombia
                Motherboad name: Samsung 500P4C/Q470C
                Chipset: Intel Panther Point HM76, Intel Ivy Bridge
                • samanthban
                  • Feb 2014
                  • 253
                  • Sri lanka
                  bios backup??this is not the board number.
                  sigpic
                  • MCardona81
                    • Oct 2016
                    • 11
                    • Colombia
                    Bios backup: https://1drv.ms/u/s!AhuvrqFPF0hqi0OhqfawitgmZbWu
                    motherboard : BA92 -11529B
                    • samanthban
                      • Feb 2014
                      • 253
                      • Sri lanka
                      No ME region in your backup
                      sigpic
                      • Kjell
                        Samsung Series 9 - BIOS issue
                        by Kjell
                        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                        08-01-2025, 09:15 AM
                        09-07-2024, 05:50 AM
                      • Nairolf
                        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                        by Nairolf
                        I have a Samsung DM32D display.
                        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                        Here’s what I have tried so far:
                        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                        From these tests, I suspect the problem might be on the mainboard. Could anyone...
                        08-24-2025, 03:47 AM
                      • vincentedel
                        Samsung SyncMaster 740n Phase Control Issue
                        by vincentedel
                        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                        04-22-2025, 12:33 AM
                      • Manucsl
                        QE65Q800TATXXC Samsung TV Issue
                        by Manucsl
                        Hello.
                        My TV is a QE65Q800TATXXC Samsung TV.
                        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                        Any ideas to check would be very appreciated 😊
                        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                        02-19-2025, 07:47 AM
