Clevo W251ESMB no DD_ON thus no VDD5.
  • f-bone
    • May 2013
    • 96
    • Greece
    Hi guys,
    I got this dead Clevo which only measures VDD3 but is missing VDD5.
    There is no DD_ON signal to enable VDD5 but if I lift the corresponding pin from ITE8518E and force DD_ON then VDD5 appears.
    I reflashed the BIOS and EC and also replaced ITE8515E. No change.
    Any ideas where I should look next?
    I am using schematics for W253 as there is not exact match available.
    Thank you guys.
  • f-bone
    • May 2013
    • 96
    • Greece
    Re: Clevo W251ESMB no DD_ON thus no VDD5.
    it was the on-off button, DD_ON asserts after the button is pressed. went straight to I/O and shorted SW# pin to ground -> motherboard turned on.
    please close thread
    • Günter Schuch
      searching for Schematics & Boardview for Clevo P641HK1
      by Günter Schuch
      hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
      Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
      05-14-2025, 06:34 AM
    • techrepairheide
      Gaming laptop Clevo NH79EP with short on 5VS-rail
      by techrepairheide
      first of all I want to apologize for my bad English, but I try to give my best.
      Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
      For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
      10-13-2024, 02:49 PM
      Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic
      Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic...
      10-04-2024, 03:59 AM
    • Axton
      Bios for Clevo P670RP6
      by Axton
      My laptop has a GTX 1060 installed, but it is not recognized in the BIOS (see attachment). The chip gets warm and the fans spin. I think there is an error in the BIOS.
      Could there be a switch to activate/deactivate the graphics card?
      I am also unable to install an Nvidia driver in Windows.
      Data about my motherboard:
      S/N: 1TP670RP6310404
      P/N: 6-77-P670RP6A-N02A-B#10​
      If anything else is needed, just let me know.​...
      09-15-2025, 10:28 AM
    • TecnicaNTT
      Convert Clevo PC70DD to UMA
      by TecnicaNTT
      Can somone please help me unlock or convert this Clevo PC70DD2 BIOS to UMA only?
      The motherboard just burned a hole in the GPU VRAM VRM circuit and now there is a 19 Volt short spread across the GPU and VRAM side. I isoalted both circuits from the rest and now I can get the laptop to work and display image with integrated Intel graphics but crazy fan spin and shutdown after some minutes because of missing dedicated Nvidia GPU.
      Laptop: Clevo
      Model: PC70DD2
      Serial Number: NPKC70DD2000E0017S
      Motherboard P/N: 6-77-PC70DD2-N02C-1D
      Motherboard S/N: NKPC70D...
      11-12-2024, 05:14 AM
