Lenovo G50-70 MB problem
  • donfero
    • Sep 2016
    • 6
    • jordan
    Hi All,
    I have a Lenovo G5 i5 when i plug in the charger it turns on, the fan spins, harddisk spins, cpu heats but the display flickers and nothing displays. I know its a MB problem, what ic or part i need to check?
  • pravin6p
    • Mar 2014
    • 75
    • india
    Re: Lenovo G50-70 MB problem
    Flash the bios.
    • donfero
      • Sep 2016
      • 6
      • jordan
      Can you please instruct me how, i have tried the keyboard combination but didnt work
      • donfero
        • Sep 2016
        • 6
        • jordan
        Thx changed bios chip all working.
        • bapuchary
          • india
          lenovo g50-70 restart problem.amd radeon graphic chip,i3 processor
          i want bios software.
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • s_specialist
            Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
            by s_specialist
            Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
            07-07-2025, 11:47 AM
          • perzyk23
            Lenovo T580 - LCD Panel problem - error 0288
            by perzyk23
            Good morning,
            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
            10-25-2024, 12:42 AM
          • c.daniel
            Lenovo V310-15IKB weird bios problem...
            by c.daniel
            Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
            sn LR09493E
            MB DAOLV6MB6F0 REV. F
            The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
            Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
            Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
            08-22-2025, 05:39 AM
          • konradx
            Lenovo Thinkpad T15 Touchscreen problem bios
            by konradx
            i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
            That is my DUMP.
            My device:
            SN: PF29Y4N6
            1s20S7S2WF00PF29Y4N6
            MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
            09-06-2024, 01:33 AM
