DV9500 blue LED ring of death ?
  • BlueMidnight
    • Jan 2015
    • 489
    Re: DV9500 blue LED ring of death ?
    There's a tiny little pin on the edge of CN7 (pin 3) and another tiny one at U13 (pin 23). And that's all there is.
    • bianchi77
      • Jun 2016
      • 1121
      Ok I ll find out
      • bianchi77
        • Jun 2016
        • 1121
        where is u13 located?
        • bianchi77
          • Jun 2016
          • 1121
          found QFP 128 pins
          • bianchi77
            • Jun 2016
            • 1121
            it's connected anode of D10, that's a possibility to put a wire and push button to ground...
            • BlueMidnight
              • Jan 2015
              • 489
              The one you found is DNBSWON# / DNBSWON#1
              That is a different signal. The one you want is NBSWON1#
              • bianchi77
                • Jun 2016
                • 1121
                Ok, is there any capacitors, diodes / resistors attach to it ? so I can put a patch for my button to the ground ?
                so
                U13 pin 23 is connected to CN7 pin 3....where's pin 1 for CN7 ?
                • bianchi77
                  • Jun 2016
                  • 1121
                  I got it, it's near the label CN7...
                  • bianchi77
                    • Jun 2016
                    • 1121
                    I tried to replace all the components mention above...new twin transistor and new diode...
                    and when I turn it on...the LED near the button was on...but only few seconds...short again and off...fuse is broken (150mA) what next to analyze ?
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Is the fuse rating too low or something short in the circuit ?????
                      • BlueMidnight
                        • Jan 2015
                        • 489
                        Where did you connect the fuse? It should be connected to VAD-1 (i.e. all the current is going through the fuse instead of through PD16). PD16 can only handle 100mA continuously, so if you put a 150mA fuse in its place and it blows, something is wrong.
                        If you connected it to a spot before PD16, then I'm not sure how much current will go through it. Possibly more than 150mA.
                        Check for a short from VAD-1 to ground with a multimeter.
                        If there is no short and if the fuse was connected correctly, then the next thing I would try is to remove PU11 and PQ62, then connect the power again. Without those, the current should be close to 0 (<10mA) through the fuse.
                        • bianchi77
                          • Jun 2016
                          • 1121
                          I connected the fuse outside between the charger and input connector.....
                          • bianchi77
                            • Jun 2016
                            • 1121
                            VAD-1 , not VA ? Please see the schematic...cheers..
                            • bianchi77
                              • Jun 2016
                              • 1121
                              if it's VAD-1....it's abit odd place to put a fuse...I'll find a solderable spot on it ....do you know it ?
                              • bianchi77
                                • Jun 2016
                                • 1121
                                I pushed the button and LED at the small PCB near the button was on and nearly 2 seconds...CPU fan was going to start and the fuse was blown....
                                I guess I put the fuse on the wrong spot......fuse was located between the charger and power input connector...which draw a lot of current for the whole board...am I right ?
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  where is that push button located in schematic ? SW1 and LED 1
                                  I got it SW1 page 37...LED1....page 37 as well...
                                  • BlueMidnight
                                    • Jan 2015
                                    • 489
                                    If you want to try using a fuse again, it has to go where PD16 is. There is no other place it can go. All the current that goes into VAD-1 has to go through the fuse. If it doesn't fit, you can always use a wire or two to connect it.
                                    SW1 is the touchpad enable/disable switch. The "LED1" on that page is the signal line for LED3, and that is the amber LED for that switch. (it can show amber or blue depending on if the touchpad is enabled or not).
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      What switch do I use for turning it on ? isn't it SW1 ?
                                      • BlueMidnight
                                        • Jan 2015
                                        • 489
                                        The power switch is on a separate board. You can use it if you connect the cable to it. If you look next to the power button board connector on the motherboard (CN7), there should also be some triangular pads labeled "G1". If you short those together for a moment with something metal, it's the same as pressing the power button. The attached pic shows what they look like (circled in green).
                                        • bianchi77
                                          • Jun 2016
                                          • 1121
                                          I've checked ...there's no short on VAD-1 to ground..
                                            Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:50 AM
                                            Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
