lenovo g570 not working on battery
  • abbas_govani
    • Jul 2013
    • 89
    • India
    hi guys
    i am getting trouble in solving this lenovo g570.
    board model PIWG2 LA-675AP.
    Working fine on adaptor and charging battery. But when i remove charger laptop power off. i already changed battery. but problem remains same.
    and also checked PU401 which is TPS51125. BUT NO SUCCESS.
    please help.
    Thanks in advance.
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: lenovo g570 not working on battery
    Check the PQ303 (FET) and find the schematic.
    • smali
      • Sep 2014
      • 287
      • Pakistan
      As you said pu401 (TPS51125) which is not concern with charging or battery adopter conversion it is 5V and 3V regulator. the charging IC is PU301 (ISL6251).
      • abbas_govani
        • Jul 2013
        • 89
        • India
        pq303 is working ok. i will check isl pu301.
        • smali
          • Sep 2014
          • 287
          • Pakistan
          OK have you received battery voltage on PQ303 drain without adopter if yes then shunt the drain and source of the PQ303 without adopter for temporary checking what the result?
          • abbas_govani
            • Jul 2013
            • 89
            • India
            checked there is 11v on pq303,
            i had also replaced isl6251.
            but same working on adaptor not on battery
            • abbas_govani
              • Jul 2013
              • 89
              • India
              the laptop is charging but cuts off power when pull out adaptor. i had cross check battery battery is fine.
              i am getting 11v on every 18 v rail on battery (adaptor not attached)
              • smali
                • Sep 2014
                • 287
                • Pakistan
                oh ok it mean you have received battery voltage on rail line. i think the voltage with low ampare . check the voltage on PR302 with multimeter with battery connected only and press power Btn if the voltage is drop from 11v that mean that amp low.and also check the 3vlp on tps51125 with battery only?
                • smali
                  • Sep 2014
                  • 287
                  • Pakistan
                  and also check ENTRIP1 and ENTRIP2 section.
                  • abbas_govani
                    • Jul 2013
                    • 89
                    • India
                    there is no power on pwr btn on battery without adaptor. with adaptor all volts ok.
                    • abbas_govani
                      • Jul 2013
                      • 89
                      • India
                      on pr302 there is 11v.
                      • smali
                        • Sep 2014
                        • 287
                        • Pakistan
                        ok i think you have problem in entrip section . remove pq405 (small dual FET) near the tps51125 and then check voltage on power switch on battery only if receiving then entrip section problem.
                        • smali
                          • Sep 2014
                          • 287
                          • Pakistan
                          sorry before removing bq 405 first pq407 ( transistor) collector short with ground and check voltage on pwr btn and post on both satuation result.
                          • abbas_govani
                            • Jul 2013
                            • 89
                            • India
                            there is no power on collector while on battery.
                            but on adaptor there is 4.2 adaptor attached.
                            one more this i am having same board so i am going to replace the pq405 and pq407 and will post the result
                            • abbas_govani
                              • Jul 2013
                              • 89
                              • India
                              changed both fet pq405 and 407 but no success.
                              • abbas_govani
                                • Jul 2013
                                • 89
                                • India
                                no change in volage on pr 302.
                                had checked pin 8 3vlp reading is 3.351 v
                                • meritosari
                                  • Oct 2010
                                  • 774
                                  • Indonesia
                                  -voltage PD101,PQ101?
                                  • smali
                                    • Sep 2014
                                    • 287
                                    • Pakistan
                                    do not replace as i said in above post first short the collector pq407 ( center pin) with ground and check voltage on power switch if no change then remove pq405 and check if voltage receiving on switch then you have problem with PD101 and pq 101 where you have not receiving the VS voltage from pq101 or pd 101.
                                    • smali
                                      • Sep 2014
                                      • 287
                                      • Pakistan
                                      and also check Pu101 (LM393)
                                      • ferah831208
                                        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                        by ferah831208
                                        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                        03-18-2025, 01:18 AM
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • Grafnus
                                        Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                                        by Grafnus
                                        Hey there,
                                        first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                                        So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                                        Specs:
                                        • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                                        • CPU, GPU, RAM work fine (not involved in the Problem)
                                        So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                                        Now I noticed...
                                        Today, 11:54 AM
                                      • code share
                                        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                        by code share
                                        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                        Here's what I've tried so far:
                                        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                        • Booted successfully on AC power only with the battery disconnected
                                        • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                        • Battery
                                        04-21-2025, 12:50 PM
                                      • mrkmpn
                                        Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                                        by mrkmpn
                                        Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                                        This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                                        03-13-2024, 01:54 PM
