Acer 5738zg Black Screen
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello guys,
    i have here a Acer 5738ZG with motherboard JV50-MV DDR3 M92 MB
    GPU and Chipset reflowed, all bga are getting Hot but i still get a black screen.
    Do you think that i should reflash bios, or it's a waste of time ?
    Any help apreciated.
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Acer 5738zg Black Screen
    amd or intel ?
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      Originally posted by dellxps15
      amd or intel ?
      Intel Buddy !
      • sopik78
        • Nov 2013
        • 519
        • Czech Republic
        Reflow is a waste of time. Do a reball of GPU or change it and youl'll see. Of course you can try reflash BIOS first.
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          i would first try bios . if that doesnt help, i would probably reball the intel northbridge ( if it is the small one, reflow wont help. u have to reball it.
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            As i suspected, no change after bios flash !
            Is this the big or small chip ?
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              umh that looks like an old mainboard core 2 duo. check all coils voltage when it turns on.
              • passete
                Living=Sharing
                • Jun 2015
                • 487
                • France
                Do i need to measure both contacts of the coil ?
                Like black probe on ground and red on both points ?
                thanks buddy
                • dellxps15
                  • Feb 2014
                  • 1598
                  • italy
                  just one pint, as difference is very low voltage change.
                  • passete
                    Living=Sharing
                    • Jun 2015
                    • 487
                    • France
                    I have measured both contacts on all, except L11 and L17, because the heatsink i can't access second contact.
                    Voltages are not stable at all, almost on all coils.
                    L10 0,80V 0,81 goes up and down , sometimes was at 1,24V
                    L11 0,20 can't measure the other side
                    L17 0,18 can't measure the other side
                    L19 0,93 -3,38 (- means negative voltage)
                    L25 1,07 -1,14
                    L26 1,54 -0,30 Changing value constantly
                    L27 5,13 3,75
                    L28 0,48 3,42
                    Hope you can help me.
                    • dj_ricoh
                      • 2073
                      L25 1,07 -1,14
                      L27 5,13 3,75
                      L28 0,48 3,42
                      make a high quality picture of the whole board.
                      • passete
                        Living=Sharing
                        • Jun 2015
                        • 487
                        • France
                        I can also make a photo of a particular component, if needed.
                        • dj_ricoh
                          • 2073
                          yep.
                          this weekend i will help you fix it.
                          mine its the same. mine got the lcd connector broken.
                          even like that it outputs to external both vga and hdmi.
                          i keep it to test memory and CPU's
                          • passete
                            Living=Sharing
                            • Jun 2015
                            • 487
                            • France
                            Where are you dellxps15 ?
                            Need help guys please.
                            • dellxps15
                              • Feb 2014
                              • 1598
                              • italy
                              if cpu and gpu get hot could be: vga bga problem that need reballing or bad memory ram or bad bios.
                              • passete
                                Living=Sharing
                                • Jun 2015
                                • 487
                                • France
                                The voltage of the coils that i measured are good ?
                                • dellxps15
                                  • Feb 2014
                                  • 1598
                                  • italy
                                  i see no vga core and no cpu core.
                                  how much resistance to ground without any kind of power on l L19 ?
                                  • passete
                                    Living=Sharing
                                    • Jun 2015
                                    • 487
                                    • France
                                    Both pins give 08,2 ohms to ground
                                    What do you mean that you don't see vga and cpu core ?
                                    • dellxps15
                                      • Feb 2014
                                      • 1598
                                      • italy
                                      i mean no voltage. u dont have vga core and cpu core voltages.
                                      check cpu vcore ic voltages on all pins. or almost the most important ones.
                                      • passete
                                        Living=Sharing
                                        • Jun 2015
                                        • 487
                                        • France
                                        Sorry Buddy, but i'm Learning everyday.
                                        Can you tell me which ic do i need to measure ?
