Hiii frnd i have nal60 la-5691p rev 1.0 motherboard in facing the problem when im press power on the power on led on but all motherboard not generates any one have any idea plz reply
Nal60 la-5691p rev 1.0
by G33RTDoes the Voltage Regulator ISL95859C supply +5 volt at pin 34 for the mosfet drivers or integrated Power Stages ?
https://www.farnell.com/datasheets/3109343.pdf -
by caspianDear members,
I have an HP Elitebook 2540P laptop with mainboard: LA-5251P REV 1.0
It has a SIO with model: SMSC KBC1098
I think both the EC firmware and the main Bios reside in a single Bios chip.
Problem: KBC1098 is partially defective so that it does not generate ADP_En at Pin 75 and generates 8 amber blinks on the charging LED, indicating some wrong input.
Idea: Now I need to modify the EC firmware so that KBC1098 ignores the wrong input conditions and always generates a high ADP_En and does not enter a failure state.
Is it possible...-
Channel: BIOS Requests ONLY!
05-21-2024, 01:35 PM -
by totofHello,
I have a Lenovo Ideapad 3-15ALC6 computer that I'm trying to repair.
Initially, the computer wouldn't start, and there was no power consumption from the charger. The board itself is reference HS261&HS561&HS761 NM-D521 rev 3.0, where you can find the schematic and board view here: https://www.badcaps.net/forum/troubl...-hs761-nm-d521
When I opened it, I noticed three burnt components near...10-26-2025, 10:27 AM -
by jasko_jackerHi, all
LA-L191P BQ24781 signals pin 28 -> 19V [VCC], pin 5 -> 3.3V [ACOK] pin 6 [ACDET] 2.6V, pin 24 -> 5.3V [REGN], pin 25 -> 5.3V [BTST] ,
missing +3VLP -> EC -> signals for manage BQ24781. In the power sequence the +3VLP is the first signal in AC mode.
I presume that the bios is working because one time the motherboard generate +3VLP and goes ON but after a shutdown the situation
came back to no power on -> no main 19V. The question is: who generates +3VLP which is the basis of all other signals?
Every time with the BQ24780S it's like... -
by Robin45Hello everyone. I received an HP 15-cx0054ur (DPk54 LA-F841P Rev:1A) with a problem - it won't turn on. During the inspection, I found a faulty chip marked 8AAB0G , but I couldn't find any information about it. In the board viewer, it is marked as PUH1 , but I don't have a full schematic. According to the board viewer, this is a power controller that generates +0.95VS_VCCIO . If anyone has an alternative marking for this chip, a partial schematic with it, or any other information, I would be very grateful .
LA-F841P Boardview - https://www.badcaps.net/forum/troubl...-hardware-devi... - Loading...
