dell latitude e5400 power problem
  • The ENIGMA
    • May 2015
    • 47
    • Egypt
    hello everyone
    I have a power problem with dell latitude e5400
    leds flash less than a second
    when I press power button nothing happened when I disassemble it
    one of ram sticks was not properly set
    I measured some diods,, fuse,,, big resistant parts,, some mosfets
    19.25 volt was measured on the input jack no PWM ices getting heat up
    north and south bridges seem fine
    I tested board with/without ram and cpu no power
    where do I began test
    please guys help still newby in this job
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: dell latitude e5400 power problem
    [*]check the power adaptor try another good
    [*]check the power button
    [*]with the schematic diagram check the 3 and 5volt page 45 on the sch pl44 and pl50 voltage must be 3.3V and 5volt if there is no voltage check without adaptor for short
    here i upload the schematic
    good luck
    • The ENIGMA
      • May 2015
      • 47
      • Egypt
      teslam
      I was looking for this schematic all day
      something suspicious ,, adapter it reads
      18.7 ~ 19.41 not stable read gonna chek my multimeter and try another adapter before it gets deep
      thanks I will do some check and replay
      thanks and peace for all Tunisians
      • The ENIGMA
        • May 2015
        • 47
        • Egypt
        there was some changes in numbers
        my board is a business class
        i have found the PWM chip pu79 SN0608098
        all check points were good
        1.3, 2.0, 3.3, 5.0, volts
        there was broken resistant PR650 connected to pin 19 "PR659 on the schematics"
        with value 10.3 K and it has something to do 5.0v VCC or 5V_ALW_2
        schematics did not mention exactly PR650 but it is in the same position of PR659
        also the track is lost hopefuly i was able to discover the lost track wider than the resistant size
        10R3 means 10.3 K right?
        whant could be done
        apreciate your help and your time
        • polytek
          • Dec 2013
          • 496
          • TUNISIA
          good news,
          i think the resistor PR650 is ok 10R3=10.3 OHM
          check PU80.5=3.3VOLT PU80.7=5VOLT
          try with this schematic diagram
          • The ENIGMA
            • May 2015
            • 47
            • Egypt
            yes pin no 5 3.3v and pin 7 5.0v
            what next,,
            • foramlaptop
              • Feb 2015
              • 50
              • pakistan
              hi gays i am rt-809f programmer use (st 45pe16vg) 8pin 16 Mbit, low-voltage, Page-Erasable Serial Flash memory e5400 mostly this ic bad
              • onlinejaved
                • Aug 2017
                • 4
                • India
                hi guys
                i have a problem with dell latitude E5400.
                when i plug in a/c adapter in my laptop, the adapter led goes to turn off.
                i have done with power drain and bios reset but same problem.
                i disassemble it and check with multimeter and found some capacitor's like pc41, pc497, pc493 comes with shorting beep.
                please help me with component should be replace.
                and sorry for weak english.
                motherboard model foose intel 14 mb 07236-2.
                thnx for your appreciation
                • Magnusa2
                  • Jul 2017
                  • 66
                  • India
                  pls help
                  bios
                  • Magnusa2
                    • Jul 2017
                    • 66
                    • India
                    on off problem
                    plz help
                    • ravi_1617
                      YY Solutions
                      • Jan 2012
                      • 348
                      • India
                      Originally posted by polytek
                      good news,
                      Thankyou ,its matching
                      for others to help if Serching
                      Foose Intel 14MB
                      07236-2(brcm 5761)
                      other side writen
                      pwa p/n:RM833.C951C
                      PWB P/N:C945C
