dell latitude e5400 power problem
  • The ENIGMA
    • May 2015
    • 47
    • Egypt
    hello everyone
    I have a power problem with dell latitude e5400
    leds flash less than a second
    when I press power button nothing happened when I disassemble it
    one of ram sticks was not properly set
    I measured some diods,, fuse,,, big resistant parts,, some mosfets
    19.25 volt was measured on the input jack no PWM ices getting heat up
    north and south bridges seem fine
    I tested board with/without ram and cpu no power
    where do I began test
    please guys help still newby in this job
  • polytek
    • Dec 2013
    • 497
    • TUNISIA
    • find the solution to the difficult problem
    Re: dell latitude e5400 power problem
    [*]check the power adaptor try another good
    [*]check the power button
    [*]with the schematic diagram check the 3 and 5volt page 45 on the sch pl44 and pl50 voltage must be 3.3V and 5volt if there is no voltage check without adaptor for short
    here i upload the schematic
    good luck
    • The ENIGMA
      • May 2015
      • 47
      • Egypt
      teslam
      I was looking for this schematic all day
      something suspicious ,, adapter it reads
      18.7 ~ 19.41 not stable read gonna chek my multimeter and try another adapter before it gets deep
      thanks I will do some check and replay
      thanks and peace for all Tunisians
      • The ENIGMA
        • May 2015
        • 47
        • Egypt
        there was some changes in numbers
        my board is a business class
        i have found the PWM chip pu79 SN0608098
        all check points were good
        1.3, 2.0, 3.3, 5.0, volts
        there was broken resistant PR650 connected to pin 19 "PR659 on the schematics"
        with value 10.3 K and it has something to do 5.0v VCC or 5V_ALW_2
        schematics did not mention exactly PR650 but it is in the same position of PR659
        also the track is lost hopefuly i was able to discover the lost track wider than the resistant size
        10R3 means 10.3 K right?
        whant could be done
        apreciate your help and your time
        • polytek
          • Dec 2013
          • 497
          • TUNISIA
          good news,
          i think the resistor PR650 is ok 10R3=10.3 OHM
          check PU80.5=3.3VOLT PU80.7=5VOLT
          try with this schematic diagram
          • The ENIGMA
            • May 2015
            • 47
            • Egypt
            yes pin no 5 3.3v and pin 7 5.0v
            what next,,
            • foramlaptop
              • Feb 2015
              • 50
              • pakistan
              hi gays i am rt-809f programmer use (st 45pe16vg) 8pin 16 Mbit, low-voltage, Page-Erasable Serial Flash memory e5400 mostly this ic bad
              • onlinejaved
                • Aug 2017
                • India
                hi guys
                i have a problem with dell latitude E5400.
                when i plug in a/c adapter in my laptop, the adapter led goes to turn off.
                i have done with power drain and bios reset but same problem.
                i disassemble it and check with multimeter and found some capacitor's like pc41, pc497, pc493 comes with shorting beep.
                please help me with component should be replace.
                and sorry for weak english.
                motherboard model foose intel 14 mb 07236-2.
                thnx for your appreciation
                • Magnusa2
                  • Jul 2017
                  • 66
                  • India
                  pls help
                  bios
                  • Magnusa2
                    • Jul 2017
                    • 66
                    • India
                    on off problem
                    plz help
                    • ravi_1617
                      YY Solutions
                      • Jan 2012
                      • 351
                      • India
                      Originally posted by polytek
                      good news,
                      Thankyou ,its matching
                      for others to help if Serching
                      Foose Intel 14MB
                      07236-2(brcm 5761)
                      other side writen
                      pwa p/n:RM833.C951C
                      PWB P/N:C945C
                      • Elios
                        • Feb 2026
                        • 5
                        • Congo-Kinshasa
                        Hello, ​I am looking for a functional BIOS dump for a Dell Latitude E5400.
                        ​Machine Specifications:
                        ​Brand: Dell
                        ​Model: Latitude E5400
                        ​Motherboard Model: FOOSE INTEL 14 MB 07236-1 (48.4X703.01)
                        ​Service Tag / Serial: Unknown (Label is missing from the chassis.
                        The laptop currently shows a black screen upon power on. No logo or BIOS access is possible. I have already tried basic troubleshooting without success and suspect a corrupted firmware.
                        I have attached my original backup for reference .
                        ​Thank you for your time and assistance.
                        • mon2
                          • 16214
                          Wrong forum. Can you post the same details inside the dedicated bios sub-forum? See above.
                          • xzomboex19x
                            Dell latitude 5590- Dead, No Power draw, lights or anything.
                            by xzomboex19x
                            I have a Dell latitude 5590 of unknown history. exterior looks mint/ barely worn but it is completely dead. I am a complete novice in board repair but do have a background in small appliance repairs so not a complete noob, but close. I have done the usual things i know of o try and revive d dead laptop for example opened up the laptop, disconnected the battery, RTC battery and while unplugged form the charger shorted out the battery pins in the RTC BATT connector. and this has not changed anything.
                            I took out and re seated the RAM modules and no difference.
                            I took out my multimeter...
                            01-16-2026, 08:10 AM
                          • masoksian
                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                            by masoksian
                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                            The system does not turn on, there is no post.
                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                            The problem continues in the same way.
                            I tried to turn on the Fn key, nothing came to the screen....
                            02-15-2025, 12:08 PM
                          • ARS
                            Dell Latitude 5501 LA-H182P wont power on
                            by ARS
                            Board was water damaged with short on 13,5V power line.
                            After celaning and removing short on board i have 5v, 3,3v, 1v, 1,8v but no reaction to power button. Its same if i use USB-C or normal power supply.
                            No shorts detected (only CPU power is 1.2 Ohm, but thats OK i think) no other water damage found.
                            Tried to flash BIOS, no change.
                            After pressing power button i get orange light in front (no light on power button LED) as long button is pressed.
                            Advice needed.
                            TIA Matus.
                            11-13-2025, 08:26 AM
                          • Stevechurch
                            Dell Latitude 7480 no power
                            by Stevechurch
                            Hi and thank you for reading my post
                            i have a Dell Latitude 7480 laptop with no power
                            Service Tag D3WGXF2
                            it doesn't power on or show any sign of life so i removed the battery and tried again,
                            the power button lights up for 12 seconds then goes out, no keyboard lights or anything on the screen
                            i have checked
                            pin 3 on ISL 88738 and it has 13.5v
                            pins 2,3,4+5 on PU100 all 13.5v pin 17=3.3v
                            pin 17 on PU102 = 3.4v pin 3=13.5v and pin15 =5.1v
                            on UT2 pin 8=3.2v
                            on UT6 pin 8=3.2v
                            the charging circuit draws 19-20v for a limited time...
                            01-18-2026, 06:19 AM
                          • imedbox
                            Dell Latitude 5440 no power on
                            by imedbox
                            ihave the same probleme the labtop want charge with the power supply! my bat is decharged then i can test it with battry it power on!
                            i got this after flash bios "XM25QH256C" for removing admin password,i revert to the original then not charge or power on, befor it power on and chargin!
                            Any Help !
                            her link for Boardview and the Schematic
                            Dell Latitude 5440
                            bios version : 1.12.20
                            MTHERBOARD : IDB40 LA-M401P Rev:1.0(A00) 2023-11-10
                            https://www.transfernow.net/dl/20250721QpvcJ0UG
                            07-21-2025, 03:03 AM
