Asus N550LF no power
  • PowerIC
    • Oct 2010
    • 11
    • NA
    Very strange case
    This motherboard as all the primary voltages and Bios IC was replaced with new one as the original failed to programm.
    Power Button as 3.3v and when pressed voltage drops to 0 but motherboard does not start.
    There is no led activity at all but battery charges.
    Any sugestion ?
    Thanks in advance
  • kotnatan
    Banned
    • Apr 2014
    • 181
    • Ukraine
    Re: Asus N550LF no power
    first - KBC firmware (U3001 - IT8585E)
    the second - to verify the conditions EC commanded start
    • PowerIC
      • Oct 2010
      • 11
      • NA
      Thanks for your quick reply
      How can i program firmware on that IC ?
      Is it better to replace with a new one ?
      • kotnatan
        Banned
        • Apr 2014
        • 181
        • Ukraine
        http://svod.od.ua/produktsiya/124-programmer-kb9012
        • PowerIC
          • Oct 2010
          • 11
          • NA
          Will post result after test
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • ShadowAi
            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
            by ShadowAi
            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
            03-15-2024, 10:46 AM
          • meraklinetx
            Asus Z97-a power cycle, no boot no cpu voltage
            by meraklinetx
            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
            05-10-2023, 06:08 AM
