hp 3-in-1 Diagnostics USB key
  • freecom
    • Nov 2011
    • 18
    • greece
    hello
    i found that
    hp 3-in-1 Diagnostics USB key.....is a powefull usb for repair all bios problems
    for hp
    ftp://ftp.hp.com/pub/softpaq/sp72501-73000/sp72954.exe
    after download about 1.2gb file i try to create usb but all times
    i take error "not enough space on disk"
    im gona be crazy
    i think is very powerfull tool....so must found the way to try it
  • diif
    • Feb 2014
    • 6978
    • England
    Re: hp 3-in-1 Diagnostics USB key
    How big is your USB ? I'm downloading it now to check but maybe it's to large for your USB stick.
    • freecom
      • Nov 2011
      • 18
      • greece
      i try 3 usb
      8gb
      16gb
      32gb
      all takes error
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        Do you have files on any of those USB drives? If so, relocate the files, format the drives, and retry.
        Permanently Retired Systems:
        Kooky and Kool Systems
        sigpic
        • sda sad
          my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
          by sda sad
          Hope this is the right place, someone can help me.
          My laptop started having a really strange problem....
          When I turn it on the fans start working at a crazy rate and with random breaks...
          They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
          And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
          The model of the computer:
          Xiaomi Notebook Pro X 15 OLED (A30)
          04-23-2024, 09:55 AM
        • marce002
          Macbook Core i7 2010 a1286 820 - 2850A CRAZY JUMPING voltages
          by marce002
          Hello
          Need just to know how do you guys determine what the problem is, when we have some fluctuating volt, to discard a faulty TPS 51125 , or if the issue is after this IC.
          CRAZY JUMPING
          PP3V3_S5 = 0v to 3.33 v jumping
          PPBUS_G3H = 12.4v to 12.48 jumping a little
          PP5V_S5 = 2v to 5v aprox, jumping fast
          P3V3S5_ENTRIP = crazy jumping from low volt
          SMC_PM_G2_EN = jumping 0v to 3.3v crazy
          STEADY
          P3V42_G3H=3.39V steady
          PP5V1_CHGR_VDD=5.06v steady
          PPCHGR_DCIN= 18.29 to 18.31 jumping
          09-08-2021, 04:08 PM
        • cruiser_
          A1502 - unable to run diagnostics
          by cruiser_
          A1502 / 820-4924-A. Unable to run diagnostics or recovery over internet.
          Getting errors -1003F or -1003D shorty after inputting wifi details.
          Runs Catalina & Big Sur fine. EFI updated to latest for the model (481).
          I can register it with my iCloud / FMA.
          Tried replacing the SSD, installing fresh OS, replacing wifi card.
          Tried different 'internet routes' (APs). Tried disabling FMA.
          Even stood up a custom AP where I can sniff traffic - macbook successfully looks up osrecovery.apple.com and connects on port 80 (dumping below some...
          06-01-2023, 03:12 AM
        • paparazzo79
          Lenovo Tab 2 Pro display "going crazy"
          by paparazzo79
          Hi guys
          I got myself Lenovo TAB 2 Pro at Friday.
          I did used it whole Friday just to test it and it was working normally.
          I installed few apps and charged it via regular USB 3.0 port on my laptop.
          After that I noticed that tablet behaves like it has a virus.
          Suddenly it just registers touch input, byitself starts to exit from tabs,volumes up or down,freezes,when press home key does not register etc etc..
          I remember I did cleaned it yesterday with isopropyl but I put the alchocol on dry cloth and cleaned the screen and metal housing...
          really few...
          02-26-2023, 12:31 AM
        • bpjl
          Dell E7450 LA -A961P - diagnostics after flooding and damaged PD817, PD5 diodes
          by bpjl
          I have La-A961P Rev: 1.0 (A00) from a flooded laptop on the table. The computer was flooded with tea and at the same time the power supply was disconnected, the battery was removed immediately and the laptop was turned upside down.
          I looked at the mainboard, but I don't see any marks of water damage. Maybe the liquid did not reach MB, or maybe I just don't see it.
          During the inspection, I noticed a burned (charred on one side) double diode PD817.
          Voltage drops during PD817 measurements:
          - PIN1-PIN3 forward biased = 0.137V...
          01-27-2025, 03:01 PM
