Charger IC normal pin values
  • LiquidCap
    • May 2013
    • 21
    • us
    Anyone know the normal operating voltages of all pins for MAX8731A? Seeing some weird values. Need to know what each pin should read under normal conditions.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: Charger IC normal pin values
    all u neeed is in the datasheet
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
    • Instafixx
      Macbook A2179 820-01958
      by Instafixx
      Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
      The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
      I checked the Power Sequences below and found this -
      Once a valid external power source (Charger or battery) is connected, the following rails will come online.
      PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
      PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
      05-20-2023, 05:19 AM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • proxneo
      Recapping Sony ICF-SW55 - verifying cap values
      by proxneo
      Dear reader
      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
      At the moment, I have selected replacements based on the following list of values:
      3 x 470uF 10VDC
      3 x 4.7uF 35VDC
      4 x 47uF 50VDC
      8 x 22uF 6.3 VDC
      1 x 220uF 6.3VDC
      5 x 100uF 6.3VDC
      Which...
      06-21-2023, 12:38 AM
