Laptop Repairing
  • Hasith
    • Dec 2015
    • 35
    • Sri Lanka
    Laptop Repairing
    I'm currently doing some laptop part level repairs and looking forward to learn chip level repairing. Any suggestions for me to find tutorials and videos which I can use for the purpose?
  • Hasith
    • Dec 2015
    • 35
    • Sri Lanka
    Re: Laptop Repairing
    bump
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      http://adiedkhazbook.blogspot.in/p/blog-page_5369.html
      • Hasith
        • Dec 2015
        • 35
        • Sri Lanka
        Thank you... Any other...
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
        • Sanjit Keskar
          Laptop mouse & KB NOT available on power option restart but available only when laptop is cold booted using power button
          by Sanjit Keskar
          I have this inexplicable problem from yesterday
          Each time i start my laptop by pushing the physical power button in, the laptop keyboard and touchpad are available to me for use when the system has booted to the desktop (I can enter the bios by pressing on F10 too) irrespective of whether the laptop is powered by the AC adapter or the battery. This is normal behaviour
          BUT NOW FOR THE ABNORMAL PART
          However, when using the laptop normally, if i choose restart from the power options, the touchpad and mouse are non-functional when the system has booted to the...
          06-06-2024, 10:35 AM
        • jrodefeld
          Asus laptop won't boot (no power) - possible bad caps?
          by jrodefeld
          I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
          The model:
          Asus Zenbook Pro Duo UX582L
          I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
          However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
          09-02-2024, 04:55 PM
        • Benass
          Surface Laptop 3 Not Detecting SSD - Need Help!
          by Benass
          Hey everyone,
          I'm having an issue with my Surface Laptop 3, and I could really use some help. I've tried everything I can think of, but my laptop just won't detect any new SSDs I install. Here's a rundown of the situation:
          Problem:
          • My Surface Laptop 3 isn't detecting any new SSDs, including a Sabrent Rocket 2230 256GB NVMe SSD and a Dogfish 256GB M.2 2230 NVMe PCIe Gen 3.0 x4 SSD.
          • Both SSDs work fine in other laptops, so I know they are functional.
          • The laptop does detect a Forsee 64GB SSD from my Steam Deck, and I can successfully install Windows on it.
          What I've Tried:
          1. Compatibility
          07-22-2024, 11:26 PM
        • ahmarzo
          Hp 15-cs laptop 5 times dc jack blinking white
          by ahmarzo
          I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
          First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
          Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
          But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
          12-28-2024, 04:46 AM
