acer 5734z no power issue.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hi guys.
    i got here acer 5734z mobo no power.
    checked 3.3v and 5v alws good.
    checked all coil for short good.
    check power switch good..
    dont know what should be to check next?
    tnx.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    Re: acer 5734z no power issue.
    sorry i did not mention after i press power on 3.3v and 5v goes off.
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      check the EC to make sure pin8 is not short to ground
      • rickybucalan
        • May 2013
        • 322
        • philippines
        hello guys anyone who have diagram for this model LA-4855P tnx.
        • rickybucalan
          • May 2013
          • 322
          • philippines
          its wasn't short to ground...
          • rickybucalan
            • May 2013
            • 322
            • philippines
            hello guy.. now my problem get worst the 5v and 3.3v coil is shorted.
            tried to removed dc regulator ic PU4 but still shorted coil.
            tried to removed posible shorted mosfets near PU4 but still shorted coil.
            tried to removed one coil the short gone but the caps next to it is shorted. and
            tried to removed the caps but it still shorted pad...
            is there any chance to fix it or to condemn it.
            tnx..
            • LP_tekh
              • Oct 2015
              • 95
              • Laos
              I think you killed the ec chip.
              Did you remove the battery when you replaced the keyboard?
              • dj_ricoh
                • 2073
                tnx..
                inject voltage!!!!!!!!!
                1.5v battery or a tablet battery if that 1.5v bat doesn't do the trick.
                tablet battery's are rated 3.7v so ... it may do the job
                • rickybucalan
                  • May 2013
                  • 322
                  • philippines
                  thanks but i really dont no how to do that... can you tell me what to do with that.
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • justice171
                    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                    by justice171
                    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                    1. Verified that all critical voltages are present:
                      • 3.3V and 5V are always present if DC is plugged.
                      • 1.8V on the BIOS chip is present.
                    2. Checked the power button functionality:
                      • When pressed, the voltage drops to 0V, indicating the button is functional.
                    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                      • Confirmed connectivity is intact, ruling out issues
                    11-26-2024, 12:39 AM
                  • claws77
                    Acer Sf314-41 power issue
                    by claws77
                    my laptop has a weird power-on issue.
                    Once the laptop has been powered on, it can restart/ wake just fine on battery power or Adapter, ONLY If i have not closed the LCD.
                    If i am running on battery and have closed the LCD (even momentarily). it will not power-on/ wake-up on battery power no matter the battery percentage.
                    but once i open the LCD and connect it to the adapter (even momentarily) it will wake up gain and I wont experience any issues till i close the LCD.
                    i do not know where to look for repair.
                    thank you all for any advice.​
                    04-30-2024, 04:36 PM
                  • claws77
                    lenovo flex 5 14itl05 power sequence issue
                    by claws77
                    hi guys, my motherboard will not start no matter what
                    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                    but rest nothing happens no sign of life.
                    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                    i have no knowledge of motherboards ....
                    10-20-2024, 02:48 PM
                  • usbdevice
                    Acer X223HQ (Version Bbd) on/off-power-cycling
                    by usbdevice
                    Hi all
                    There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                    https://www.badcaps.net/forum/showthread.php?t=50657
                    https://www.badcaps.net/forum/showthread.php?t=40512
                    The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                    It's my dad's old monitor. He...
                    08-05-2022, 02:21 AM
