Asus X551CA no power and no led
  • von mac kraken
    • Mar 2017
    • reunion island
    #41
    Re: Asus X551CA no power and no led
    Originally posted by meritosari
    I've got the boardview and share it for this forum
    thank it's good for me....
    • siroos_tz
      • Feb 2014
      • 120
      • the UK
      #42
      Thank you for the BoardView.
      • gsmobile
        • Mar 2020
        • romania
        #43
        hi, can you help me? i have a asus x551ca series and i have same probleme like you, no power and no led, any ideea how to solve this?
        • thytum
          • Apr 2021
          • brasil
          #44
          Thanks a lot!
          • Sametbey
            • Jan 2021
            • 229
            • Turkey
            #45
            Check the mosfets at the dc jack input. one can be short circuit.
            I'm not happy to be so strong. because it's not humanly
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • ShadowAi
              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
              by ShadowAi
              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
              03-15-2024, 10:46 AM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
