sony vio model PCG-71211W POWER LED LIT ALTERNATE.
  • AltraqComputer
    • Sep 2015
    • 10
    • philippines
    GOOD DAY TO ALL,
    kindly help for this issue, press power button led lit and off then few second lit again., please see attached video clip for the issue. thanks to all.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: sony vio model PCG-71211W POWER LED LIT ALTERNATE.
    try to reflow GPU or flash bios
    • AltraqComputer
      • Sep 2015
      • 10
      • philippines
      hi good eve
      do you have a bios of this model i don't have it, and thanks by the way for giving some of your ideas.
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        Originally posted by AltraqComputer
        hi good eve
        MBX....?? motherboard code need
        • AltraqComputer
          • Sep 2015
          • 10
          • philippines
          hi good day, very sorry for late reply.
          here is the mbx. picture.
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Akuanka
            Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
            by Akuanka
            I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
            Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
            Thanks in advance for your help!
            11-23-2024, 01:12 PM
          • claws77
            lenovo flex 5 14itl05 power sequence issue
            by claws77
            hi guys, my motherboard will not start no matter what
            when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
            but rest nothing happens no sign of life.
            this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
            with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
            but now nothing happens no matter how much i wait/ charge/ press and hold power button.
            i have no knowledge of motherboards ....
            10-20-2024, 02:48 PM
          • PopsCaps
            Sony Bravia KDL-40V2500 that will not power on
            by PopsCaps
            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
            I do not hear any sound and I cannot see any backlight.
            I have tried disconnecting every cable on each board one at a time to see if anything changes.
            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
            03-25-2025, 11:23 AM
