DV6-6030EL Hard Disk not exist
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    ... i am going to be crazy with that laptop.
    Teste many HDD, Sata cable, bios...etc..etc..
    someone got same problem?
  • angel-boy
    • 550
    Re: DV6-6030EL Hard Disk not exist
    southbridge ...!?
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      Originally posted by angel-boy
      southbridge ...!?
      Still not reflowed... But it's strange because the laptop is brand new,never used, it was forgotten in warehouse...
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        solved
        installed ORIGINAL HDD cable
        i also installed DV6 series HDD cable, but dont work, with cable token from same notebook work fine
        • madura2010
          DAY11AM6E0 hard disk drive and optical disk drive not detected
          by madura2010
          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
          i checked the connectivity of ribbon=good communication with hard and motherboard
          changed hard disk and checked=3f0 error persist
          sata power=+5v available
          Then checked data capacitors=all good
          Then checked data lines path connectivity to pch=all good
          reflashed...
          03-12-2023, 09:09 AM
        • mkdj
          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
          by mkdj
          Dear all,
          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
          Here the steps I have taken to fix the laptop:
          - downloaded latest BIOS from Lenovo Website...
          10-18-2025, 03:43 AM
        • Eleways
          Apple Macbook A1707 Hard disk
          by Eleways
          Hi
          I've an Apple macbook A1707 with Hdd defect.
          This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
          My question is:
          Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
          Can i replace with a different one (es 500 gb instead of 250 gb)
          This Macbook has T1 security check.
          Thanks and best regards
          Luca
          02-18-2022, 04:23 AM
        • DynaxSC
          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
          by DynaxSC
          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
          The behaviour is also really very strange, i.e.:
          • The disk shows always up in BIOS - so it is recognized, so far so good
          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
          02-23-2025, 01:33 PM
        • Zentech
          Laptop Hard Disk Not Recognized By Computer
          by Zentech
          I have a laptop hard drive that I've plugged into different computers and it is not getting recognized. I'm using a usb connector/sata adapter to use it as usb storage, but "Disk Manager" is not giving me the Initialize disk option. I can scan the disk for error, I tried in Windows and Linux with same result. Is this a problem with the hard drive hardware? has anyone repair a hard drive before?...
          04-19-2021, 09:29 AM
