asus K52F short?
  • anno
    • Sep 2007
    • 140
    • netherlands
    asus K52F short?
    i have a asus K52F laptop . user said it had wrong bios flashed or gone wrong.
    I noticed high current draw in standby. visually i see nothing wrong on mainboard. i used lab power supply and noticed when i set to 3-4 volt current draw is 0.7A without battery and i touched the board and noticed PCH is getting hot. So is it possible PCH chip has a short and how can i be sure?
    are there other tests i can do. I am note sure about the diagram i can`t find it for K52F, but found an Asus K42F , one person said it was the same. correct?
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: asus K52F short?
    Maye this helps.
    https://www.badcaps.net/forum/showth...highlight=k52f
    • anno
      • Sep 2007
      • 140
      • netherlands
      hi still not solved the problem. The 5vus coil is 4k ohm to ground, but the 3.3vsus is 91 ohm to ground. is this normal? i think not?
      • dj_ricoh
        • 2073
        • uk
        so!
        my friend! diagrams !
        then we hug
        • rs232killer
          • Feb 2015
          • 89
          • Portugal
          lift bga then see what fires up
          You will need to replace bga with new one
          • atsio
            • Oct 2013
            • 819
            • Greece
            91 ohm on 3.3vsus probably has nothing to do with bga. You have a short somewhere on the 3v rail.
            • anno
              • Sep 2007
              • 140
              • netherlands
              ok. so 91 ohm to gnd on 3.3vsus is not normal. good to know. now i try to find the short. that is not easy isn't it ?
              • dj_ricoh
                • 2073
                • uk
                depends !?!?!?
                how many tools you wanna use
                • anno
                  • Sep 2007
                  • 140
                  • netherlands
                  i have most tools.
                  when i give 3.3v with lab power supply, current is normal . so there is no short on the 3.3v line , i think. still has lot to learn.
                  • anno
                    • Sep 2007
                    • 140
                    • netherlands
                    i have schematic that are similair. where do i start. can anyone help me with this?
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      Originally posted by anno
                      i have most tools.
                      When you give 3.3v with lab power supply, it should not draw any current. Just check with a thermocouple what is getting hot.
                      • Vincent Kahle
                        Winbond 25Q16JWNIG – Asus ROG Strix Scar 18 G814JZ bricked after wrong flash – Need help
                        by Vincent Kahle
                        I hope someone can help me.
                        I have an Asus ROG Strix Scar 18 (G814JZ) laptop with a Winbond 25Q16JWNIG chip on the motherboard.
                        Unfortunately, I flashed the wrong file (BIOS/EC/other region – I'm honestly not sure anymore), and now the laptop is completely dead: no display, no fan spin, no reaction at all.
                        I have a CH341A programmer and I'm able to read and write to the chip. However, I'm not sure which software is best (AsProgrammer, NeoProgrammer, etc.) or if there's anything specific I should watch out for.
                        A valid BIOS/EC backup...
                        06-05-2025, 09:27 PM
                      • OOF DIO
                        ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                        by OOF DIO
                        (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                        (Had 3 problems, now just 1)
                        I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                        I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                        I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                        04-19-2025, 05:03 PM
                      • jkucukov
                        Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
                        by jkucukov
                        I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
                        During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
                        02-05-2025, 09:27 PM
                        ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                        This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                        09-07-2024, 02:50 AM
                        ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                        This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
