hp g62 help disable DSC vga
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    #41
    Re: hp g62 help disable DSC vga
    i'm also having issues converting this board, getting white screen. Anyone has a solution yet ? i will try removing ub5, (no ub8 on board) and will add resistors near ub5 and ub8 according to the schematic. Hope it works.
    • ozturkbulent
      • Mar 2014
      • turkey
      #42
      hi g62 my laptop ı dıscaret ati screen ok but hdmı not screen please help me
      • zibi99
        • Mar 2021
        • Polska
        #43
        hi guys, ancient thread but...
        Could anybody advice Ohm rating for these R55 and R53 resitors?
        Ive burnt one of them and still try to fight with it ))..
        • ale_cpm
          • Mar 2021
          • Italia
          #44
          White the ITE chip on top, the resistor on the left Is 10k, resistor on the right Is 100k
          • ale_cpm
            • Mar 2021
            • Italia
            #45
            Originally posted by ala_borbe
            to fully convert form DSC to UMA either remove PU320 or disconnect PJ19
            then switch resistors like in pic
            RI53 RI56 and RI51 RI55. -> SKU ID UMA
            works 100%
            sometimes you need to reflash bios after conversion
            I done the conversion due to frequently black screen on power-up, but now the Laptop do not start and caps-lock Blink One time. How to try to reflash the BIOS ?
            • openminded
              • Apr 2017
              • 73
              • home
              #46
              https://www.badcaps.net/forum/troubl...board-la-j191p ?
              I am trying to do the same on a XPS 9500 (2020) and have the schematic linked. There are some instructions that I do not fully understand, it would be great if anyone can help, thank you!
              • brotank
                Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
                by brotank
                I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
                can someone disable onboard ram from my dumped bios, please 🙏
                I tried the other bios on this forum with disabled onboard ram, but no success
                my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
                after that I officially give up 😂
                thanks for awesome jobs 😊...
                03-16-2025, 12:51 PM
              • b-slayer
                Acer A317-53 need help to disable faulty onboard ram
                by b-slayer
                Hello.
                I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                - first one is to modify le bios to disable the onboard ram.
                - second one is to disable the onboard ram by desoldering some components on the mainboard.
                so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                so i found that my motherboard...
                10-12-2024, 03:46 AM
              • Mr.Ultimate
                Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
                by Mr.Ultimate
                Hi everyone, hope to get someone to help and modify bios rom for me.
                I need to disable dedicated nvidia graphics chip permanently.
                GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
                Ideally if it was disabled from bios at preboot.
                I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
                08-06-2024, 05:15 AM
              • mat2k
                Disable faulty soldered RAM on Acer A315-22
                by mat2k
                Hello, I've been googling for some pointers on this but couldn't find anything that applies to this board. I have an Acer A315-22 (board NB8607) with faulty RAM between 142 and 174mb. I just wanted to disable the onboard RAM altogether, but this one doesn't seem to have any memory down ID resistors or strap in order to disable it. I'm attaching the schematic I found, the boardview for it also seems to be available somewhere in this forum but I still don't have a use for it lol.
                How would I disable the RAM on this PC? Thanks for the help.
                [MOD EDIT] LINK to boardview + schem...
                06-02-2024, 11:26 AM
              • bbenalmadena
                Old Sony VAIO da0hk5mb SVE1512E1E disable Radeon video card
                by bbenalmadena
                I have a Sony VAIO SVE1512E1E (motherboard da0hk5mb) video card is broken, has artifacts, I want to disable it, the processor is an I3-3110M that supposedly has an integrated Intel GPU and I want to disable the onboard Radeon so that can be used.
                I download some schematics, and tried to remove VPL1, but then the laptop starts some leds, and shut off. Should I try to lift VPL1 and VPR47 and pass a cable to one tip of VPR47 and the other back to VPU1 to see if that works or it is pointless?
                That seems to be some feedback to VPU1 and I guess if it does not detect voltage, laptop...
                08-30-2025, 10:40 AM
