C660 la-6842p WATER DAMAGED
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Hi i m working on this Toshiba WATER DAMAGED not charge no light nothing completely dead.
    i find on it PQ24 shorted with ground removed measured its ok not burned , i put it back , after i find the problem is IC 51125 replaced OK charge turn on BUT no display black screen.
    Cpu i3 heats normally, Igp HM55 stay cool , reflowed it , bios flashed no change.
    What do you think , any idea please ?
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Re: C660 la-6842p WATER DAMAGED
    Hi today received IC chip
    Changed pu5 tps 51125 CHARGE ok
    But no screen i find the problem is PU15 ADP3211A changed with new and OKOKOKOK
    turn on Video ok TOSHIBA logo ....
    Before closing i have done another test now turn of after 2 sec , no screen.. , i hear a whistle near cpu , some caps near cpu are shorted , without CPU the Mainboard stay power on , but with cpu have this problem TURN OF AFTER 2 SEC.
    Any idea please???????????????
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      Here the schematic
      • FShahid
        • Nov 2012
        • 57
        • United Kingdom
        Several reasons, first check if caps seems shorted without CPU. If it doesn't then CPU is gone and needs replacing.
        However before that make sure you have used correct components you previously replaced. Also clean the board between the components throughly (especially the places where you have changed the components and look for any excess solder) as that may have caused this new issue.
        • gcomputers
          • Apr 2013
          • 509
          • Albania
          SOLVED i bought 5 ic chips from ADP3211A replaced with another new chip and ok Works fine.
          In this mobo i replaced ic chip TPS51125= Charge ok
          no screen ic chip ADP3211A= video ok
          • RetroComputingGrotto
            Water Damaged Toshiba 48L1435DB
            by RetroComputingGrotto
            I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
            The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
            10-07-2024, 08:23 AM
          • rzsn
            water damaged G513I
            by rzsn
            Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
            Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
            12-22-2024, 09:02 PM
          • phantomEVO
            [help]820-01521 WATER DAMAGED
            by phantomEVO
            HELP! audio board+its flex+powerbtn flex water damaged (an hole on audio board)!!! chnged both, but i have 5v on both ports:
            https://files.fm/f/6gjpqyjw3q
            here some measurements
            ppbus_g3h 12,29v
            PP3V3_G3H 3,29v
            pp3v3_upc_xa_ldo pp3v3_upc_xb_ldo 3,27v
            PP1v8_UPC_XB_LDOD PP1v8_UPC_XA_LDOA 1,8v
            PP1v8_UPC_XA_LDOD PP1v8_UPC_XA_LDOa 1,8v
            PP1V1_UPC_XA_LDO PP1V1_UPC_Xb_LDO 1,1v
            with battery connected, as soon as i connect the cable, i see direclty 20v, but stuck at 0,0250
            10-24-2025, 04:23 AM
          • estabilito
            Dell Latitude E5590(La-f411p) water damaged
            by estabilito
            I have water damaged Dell Latitude E5590 around charging ic.
            Laptop was dead but i replaced some components like capacitors, resistors, resoldered charger(intersil 9538h) but traces under PQ904 dual mosfet(AOE6936) was burnt.
            I rebuilt traces and both mosfets(PQ904 and PQ905) and after all this work laptop started turning on.
            I dont have battery so i want to be sure if laptop behaviour is normal before buying.
            On PL902 i have weird voltage around 5Volts, on battery socket voltage looks normal - 13.5v.
            Is this voltage on pl902 normal?...
            03-08-2025, 06:22 PM
          • abajor
            A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
            by abajor
            Like title says A2141 came in with Water Damage, customer desperately wants the data.
            The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
            I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
            That said after cleaning up the...
            12-21-2024, 07:16 PM
