Dell LA-9104P (15r-3521)
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Strange problem.
    Sometime it turns on but after I pull out and insert battery, it doesn't turn & doesn't charge battery too. After multiple power button press it turns on again & also response for battery charge.
    Same happens with battery and direct power source.
    Changed ISL88731CHRTZ & flashed with latest BIOS but same problem. RT8205LZQW IC is ok 3.3v and 5v is present after board turns on but not available in off state.
    Power button is ok. 3.3v voltage always available in power button.
    Can anybody help me to let know the problem.
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Dell LA-9104P (15r-3521)
    Press with your fingers the PCH and EC alternatively to see if it makes any difference.
    • dspok
      • Jan 2014
      • 553
      • Nepal
      Thanks but no effect.
      Anyother idea?
      • atsio
        • Oct 2013
        • 819
        • Greece
        When you say it doesn't turn on, does it draw any amps when you press the power button?
        • dspok
          • Jan 2014
          • 553
          • Nepal
          it goes up to 0.5 and drops down to 0.1
          but interesting thing is that it doesn't charge battery.
          if it likes to turn on it charges the battery.
          • atsio
            • Oct 2013
            • 819
            • Greece
            It sounds like you have to reball the PCH
            • andrhouseolly
              Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
              by andrhouseolly
              Hi.
              I kindly ask you to help me solve the problem.
              Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
              The board turns on, there is no image.
              Read more. When the power supply is connected, the front panel indicators light up briefly.
              When you press the power button, the button indicator lights up. The board works
              there is no image, there is no matrix initialization, there is no image on HDMI.
              When turned on, the fans do not spin, but when they warm up they start spinning.
              When you turn off the button, the fans spin up to full speed for a short...
              05-11-2024, 03:14 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • retrorepair2
              Dell E5470 LA-C631p - Short removed now turns on but no post/display
              by retrorepair2
              Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
              Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
              09-25-2025, 07:12 AM
            • manol278
              Dell laptop E6440 val91 la-9934p turns off
              by manol278
              Hi. I have problem with dell laptop E6440 val91 la-9934p rev.1.
              I turn on the laptop and it turns off instantly. After 5-6 attempts it turns on normally. I saw that it was burnt PU800, CD3301B Power Controller Chip.
              If you see in the photo someone tried to do bypass and remove PR831, PR832, PC820, PR838.
              I will replace CD3301B. I have the schematic but i dont know what are the characteristics of other componets to replace...
              [Mod. Edit]
              Schematic -> https://www.badcaps.net/forum/troubl...cs-theory/trou...
              01-26-2024, 11:50 AM
            • Kambi13
              Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
              by Kambi13
              Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
              Not heat related, everything is ok regarding to that.
              All voltages are present.
              Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
              Motherboard is Cedar 13269-1 F3XMC Rev A00...
              07-12-2024, 06:10 AM
