Macbook Air A1406 WLED Driver
  • Jtroutt19
    • Aug 2011
    • 164
    Hey Guys been a minute since I posted on here.....but alas! Here is what I have going on.
    Working a customers MacBook Air Model A1406. She needed a new LCD after replacing the LCD the backlight is no longer working. The Backlight on the old screen does not work as well. Tested Backlight Fuse fuse is good. The only other thing I am thinking it could be is the WLED Driver. Is it worth Testing or should I just Replace it?
    If I need to test it does anyone know the values the thing should be putting out and also where the test points are at? Thanks for any help!
  • yakideo
    • Feb 2013
    • 16
    • Sweden
    Re: Macbook Air A1406 WLED Driver
    LED displays are pretty sturdy as opposed to CCFL screens with inverters. Most of the time when the backlight goes bad it's a problem with the logic board/motherboard. You could try to replace the WLED driver but unless you know that all the components around are fine you risk blowing that one also. Best to take some measurements before swapping.
    The values can be retrieved from the schematic however they might differ when tested in circuit. Hopefully someone else might have the same board and kind enough to do some probing. Your best bet is to start out with the schematic and the boardview.
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • dellxps15
      macbook a1707 15 inch trackpad dead. blown fuse identification
      by dellxps15
      hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
      another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
      04-30-2024, 10:48 AM
    • osrex
      LED DRIVER KEEPS DYING
      by osrex
      Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
      i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
      i have no datasheet at all for the LED lights, all i have is its length.
      long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
      as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
      05-05-2025, 03:36 PM
    • corrize
      A funny fuse story – Lumix LX100 II
      by corrize
      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
      10-19-2023, 09:58 AM
    • Flasman90
      Macbook Pro DFU Restore Issues
      by Flasman90
      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
      08-30-2025, 10:27 AM
