PB (Acer) LA-5891p mainboard not starting
  • Thakkie
    • Aug 2015
    • 7
    • Netherlands
    I have a Packard Bell (Acer) NEW70 LA-5891p mainboard that is not powering up.
    I have checked the CMOS battery and it was completely empty. I have removed the battery and found that the charge voltage is only 1 volt.
    The +RTCVREF, directly from the regulator (PU14 pin 3), is 3.3V.
    The resistance from +RTCVCC (D8 pin 3) to ground is about 180 ohms, obviously not OK.
    When cutting the +RTCVCC at D8 pin 3, the charge voltage on the battery returns to normal.
    I have checked the board for visible defects or burn marks, but found nothing.
    My hypothesis is that there is either a bad cap or that the chipset is fried.
    I'm having trouble locating the related caps as they are not market with a sikscreen.
    At the moment I do not have access to tools to reball the chip, so I'm hoping it's a bad cap or a short of some kind.
    I attached the schematics document so you can look up the test points I've mentioned.
    Could anybody please advise on how to go from here?
    Thanks in advance
    Jan
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: PB (Acer) LA-5891p mainboard not starting
    Maybe this can help. the LA-5892 is also Aspire 5741
    • dj_ricoh
      • 2073
      Yes!
      The board view will come in handy.
      The first thing you search is the always V
      3.3v and 5v on the output you will always find coils on those outputs.
      Its like this you lift the coils up and see what side its shorted.
      We go after you check the coils
      • Thakkie
        • Aug 2015
        • 7
        • Netherlands
        @bicalov
        Thanks for boardview. The LA-5892 board is quite different from the LA-5891p and unfotunately this bvd is not very useful to me. I'm trying to get a hold of the correct bvd file, but no luck yet.
        • Thakkie
          • Aug 2015
          • 7
          • Netherlands
          @dj_ricoh
          Thank you for your reply.
          I am not sure you understood my original post correctly. I don't seem to have power supply problems. +3.3VALW and +5VALW are OK as are the supply power for the RTC charge circuit and RTCREF (The output of the regulator for the charge circuit).
          I'm having issues with the RTC battery (the small lithium cell) voltage.
          The problem is that the RTC voltage is being pulled down by a short of some kind. I suspect there is a problem with the chipset (the large BD82HM55), but am hoping there could be a different problem I might have overlooked.
          By the way Voltage on both sides of PL27 is 5.1V and both sides of PL28 3.3V no need to lift them
          • bicalov
            • Nov 2014
            • 294
            • Netherlands
            I know there are principles, but $ 3,32 is not the world.
            http:/**************************.html?___SID=U
            • Thakkie
              • Aug 2015
              • 7
              • Netherlands
              Ah, think I missed that one. Thought I only got Russian and Chinese sites.
              $ 3.32 is no problem at all!
              thanks.
              • atsio
                • Oct 2013
                • 819
                • Greece
                If you buy it, please share it.
                • Thakkie
                  • Aug 2015
                  • 7
                  • Netherlands
                  Here you go!
                  • bicalov
                    • Nov 2014
                    • 294
                    • Netherlands
                    Thanks for sharing
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      • qonma
                        Kuli Solder
                        • Jun 2017
                        • 184
                        • INDONESIA
                        i have same problem....alw 3 and 5volt ready, swon 3volt, rtc 3volt, flash bios still, am reflow the chips hm55, problem solved
                        • day_see
                          • Feb 2016
                          • 10
                          • TURKIYE
                          • zpi
                            • Feb 2018
                            • 132
                            • Lithuania
                            Didn't you tried to inject few Volts to +RTCVCC ? See how many amps is used injecting 1V, if it will use something, you should be able to see hotspot with thermal cam, if you don't have it, try ouch method with your finger Off course it should be at least few wats of current to feel it.
                            • 2Stupid4U
                              Acer Nitro 5 An517-51 mainboard short circuit - Boomer needs help
                              by 2Stupid4U
                              Laptop data:
                              NTB Acer An517-51 FHD
                              i7-9750H
                              16GB replaced with RAM Crucial Ballistix SODIMM DDR4-3200 32GB K2 SW
                              1TB SSD
                              RTX2060
                              Bon soir dear online techies, enthusiasts, modest helpers and whomever I might have forgotten!
                              Search gave me no hits so this is my first post.
                              My Acer 5 Nitro mainboard had a short circuit when I tried to plugin a USB device. Some smoke rose from the port and it became super hot a that point of entry/exit. Warranty was of about a month.
                              Since I am on a low budget I cannot afford to buy...
                              08-29-2023, 01:03 AM
                              09-06-2024, 05:27 AM
                              Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                              This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              09-07-2024, 05:00 AM
                              Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                              This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                              Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                              This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 04:10 AM
