please help me! macbook pro a1278 i7. motherboard 820-2936-a
a) it says "battery not charging" 61%
b) if i disconnect the power supply, it power off
c) with only the battery, it doesn't power on
d) when i connect the power supply (with or without the battery), it power on itself
e) the led of the power supply is always green
f) i have 5/8 led on the battery only if i connect the power supply
g) i've try to reset smc. but it doesn't work (led always green)
h) if i hold for then second power button, then i connect the power supply then i release the power button, it power on with fan at max speed, but the battery is not seen anymore
i) i've try to do all those thing with the motherboard outside the case and with anythign connected, it doesn't change, i've always the same problem
