problem with laptop cq45-910LA
  • jonny0404
    • Nov 2014
    • 116
    • Colombia
    HI guys i have this laptop CQ45-910LA , when i press power button,fan try to spin but it doesn't,one light start flashing every 5 seconds,this is what i have done, i flash the EC bios, nothing, i flash the pch bios nothing,i measure EC RSMRST# and i have 3v but when i measure SLP_S3# y SLP_S4#that comes from the pch i have 3v for 3 seconds and then disappear and again 3 and the disappear,it continuously do that at the same time with that light. any idea guys, i already try a reflow on the pch I took it up to 180 degrees, and then i wait until gets cool and then i press power button and it happen the same thing.
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: problem with laptop cq45-910LA
    please post all mesure of coil to ground;
    • jonny0404
      • Nov 2014
      • 116
      • Colombia
      hi polytek thanks.
      BIG coils:
      L6000 - 165
      L6150- 109
      L6100- 94
      L6200- 150
      L6300- 47
      L6620-132
      L6610- 132
      L6710- 170
      L6500-406
      L6970-363
      • polytek
        • Dec 2013
        • 496
        • TUNISIA
        the mesure are good, there is no short, do you try another dc adaptor ?
        try to do a light reflow for the pch, and see if there is a change.
        • atsio
          • Oct 2013
          • 819
          • Greece
          109Ohm and 94Ohm are alright on the 3.3v and 5v lines?
          • polytek
            • Dec 2013
            • 496
            • TUNISIA
            sorry atsio, it's not normal for 3/5v lines, but i confused with another post that
            have 3/5v present,
            jonny0404, remove the two big coil L6100 and l6150 and mesure resistance on both side.
            • ahmarzo
              Acer TMX314-51 laptop battery problem
              by ahmarzo
              I have acer laptop tmx314-51 with part no 6050A3020501.
              The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
              But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
              I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
              The schematic is not available...
              04-11-2025, 09:14 AM
            • PacoGT
              HELP!! Dell E6440 laptop with problem does not turn off and turn itself on help
              by PacoGT
              A few days ago my laptop gave me problems, when I wanted to turn it on to my surprise without charging so I did not put much importance on it, after that I turned it on with a charger, it turned on and charged the laptop, the problem with the laptop is that when it is turned off it turns to turn on after seconds, sometimes at 2 or sometimes at 8, other than that it works normally, I already checked many things, I changed a mosfet at the charge input to a pnp but it remained the same, after that I checked and I did not find anything outside Normally, before that, it had a failure where I changed...
              07-11-2023, 09:31 PM
              Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
              This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
              09-06-2024, 09:30 PM
              Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
              This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-06-2024, 08:47 AM
            • versionlab
              Weird problem, laptop stays on when connected to another pc
              by versionlab
              Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
              Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
              After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
              10-26-2022, 03:43 AM
