Samsung NP350v5c laptop turns off randomly not overheating
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Hi my laptop turns off randomly but is not overheating,tested memory ok ,new paste on cpu,fan works ok ,temperature test is ok 50c ,Charger ok,battery ok
    Laptop bios updated ,starts normal then after 30min of use switch off ,no blue screen just like overheating but not ,could be memory controller ? voltage controller ? Any ideas
    And tried with another CPU same shit
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Re: Samsung NP350v5c laptop turns off randomly not overheating
    anyone smart
    • khaahk
      • Dec 2013
      • 817
      • Estonia
      Any anomalies - like fan spinning too high?
      Temperature tested with what?
      30minutes exactly all the time? or random?
      • ciki
        • Aug 2014
        • 132
        • Ireland
        temperature is ok 50c Realtemp
        sometimes 30min sometimes 1 hour try to live only with bios on screen same thing
        • subroto
          • Oct 2015
          • 230
          • Bangladesh
          Most probably cpu core chip failure if the temp. and BIOS are ok. Solder the core chip and check again.
          • sopik78
            • Nov 2013
            • 519
            • Czech Republic
            Most probably subroto means PCH chip, not CPU core chip itself. Try to reball or change PCH, I had many of these issues.
            • imgaurav86
              • May 2008
              • 35
              Does it have NEC tokin?
              If yes then replace it with capacitors
                09-07-2024, 05:50 AM
              • Egidio85
                Samsung UE55F8000SZ Turns on and off immediately
                by Egidio85
                good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                This defect happens continuously, hearing the classic click of the relay every time.
                Power supply board BN44-00636B
                disconnecting the mains and lamps from the power board always causes the same problem.
                Is it normal that without anything connected this power supply turns on and off cyclically?
                any suggestions on what to check?
                thanks in advance
                03-11-2025, 12:45 PM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
