Toshiba P505-8935
  • senchire
    • Dec 2012
    • 190
    • Bosnia
    Toshiba P505-8935
    Hello guys, got this one in few days ago.
    It has the notorious hd3200, while the reflow went fine, I've one another issue.
    This little fella came with ZM ultra 74 cpu unit, putting it back in gives me a big nope as it won't even turn on (turns on and off in cycle's)
    Then I dig one ZM 72 and put it in, it works give me screen but frezzes from time to time.
    Then I went with the sempron, and the laptop works perfectly fine (sempron won't accept more then 2gigs of ram).
  • dj_ricoh
    • 2073
    • uk
    Re: Toshiba P505-8935
    check the caps under.
    check the coils that goes to CPU.
    the board it's tired,old,used and i think some caps are going bad.
    i saw this with intel and i lower the cpu from i5 to i3 after.
    tough it never came back its still weird.
    • senchire
      • Dec 2012
      • 190
      • Bosnia
      I've left the sempron in it.
      Yea could be, the reflow could only fasten up things.
      What is more weird is the ram for sempron it boots up, passes memtest but if I try to load either linux from cd or system from hdd I get artifacts and the laptop frezzes (putting only 2gigs be it either x1 2gb or 2x1gb it works perfectly fine. The ZM 72 sometimes get fully booted with 2gig and 4gig works for few mins and passes out, it could maybe be that the hd3200 is playing a tricky game with me.)
      Anyhow I gave the full report (since the laptop came to me only for fixing the GPU unit), and gave it back to customer if the laptop makes trouble again I'll replace the hd3200 with a 2013+ version and will change the capacitors.
      • CapLeaker
        Dell ATX PSU won’t start, but forcing it works fine?
        by CapLeaker
        Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
        Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
        10-28-2024, 06:59 PM
        09-06-2024, 05:27 AM
      • zioricci
        Toshiba P855 only works with battery
        by zioricci
        I have a Toshiba satellite P855 that was previously stuck on the Toshiba logo and I couldn't enter the BIOS with F2 and then, thanks to the 2 original bios files that hardware1 gave me, yesterday I was able to boot it up to Windows 11. I deduced that the fault was the corrupted bios. So all the hardware works, hard drive, graphics card, RAM etc. The problem is that everything works if I power it with only the main battery, as soon as I take it out and put the charging cable in, the laptop, although it always succeeds entering bios with F2, hangs on Toshiba logo. I tried doing...
        03-31-2023, 01:24 PM
        09-06-2024, 05:59 AM
