hp cq56 blank screen
  • grec
    • Mar 2013
    • 21
    • BiH
    hello
    i have hp cq56, laptop power ok but no picture on screen, no picture on external monitor !!
    - I'm replace amd radeon 216-0752001 with new 100% original from ebay chip but not result.
    - replace bios battery
    - replace cpu
    but always blank screen. Any idea what i do !!
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: hp cq56 blank screen
    Originally posted by grec
    hello
    - replace cpu
    Try to reflash bios, but first change RAM.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • grec
      • Mar 2013
      • 21
      • BiH
      which is the mark of bios ic on motherboard?
      it's eeprom and if not how it programmed?
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • Chrissygizmo
        Panasonic TX-48CX350B backlights but white screen , blank screen
        by Chrissygizmo
        Hi all, I’ve got a problem I hope someone can help me fixi.
        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
        01-11-2025, 03:18 PM
      • benek123
        RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
        by benek123
        I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
        The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
        When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
        I checked the EDID with the old screen - it is identical.
        What...
        09-24-2024, 03:28 PM
      • dicky96
        HP Elitebook Screen blank - backlights but no image
        by dicky96
        Hi guys
        I'm trying to fix this laptop screen
        Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
        OK so I have the original screen which works but has lines across the bottom quarter of the screen
        I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
        04-28-2021, 07:30 AM
      • kotel studios
        Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
        by kotel studios
        Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
        State I got it in:
        Squealing from the PSU
        After logo I get a blank screen
        After 10 seconds of having a blank display w/ backlight the TV dies
        Give it 7-10ish seconds again and it starts to bootloop.
        What I did so far:
        Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
        Checked all voltage rails:
        5VSB - 4.8V
        AMP+13V - 14.4V
        13V - 12.98V (in manual 12V)...
        09-21-2025, 02:00 AM
