Lenovo Thinkpad E30
  • Tomas9t1
    • Apr 2015
    • 41
    • Lithuania
    Lenovo Thinkpad E30
    Hey all badcapers Today I got a present from a good friend of mine, Lenovo Thinkpad E30 and you won't believe it but it's not working So let's start with the history, it was quite a good laptop before my friend decided to upgrade Ram, then he bought some used Ram SODIMMs and they were not working in correct order so he tried replacing them while the laptop was turned on So what we have now is a laptop that does turn on but no video if I take off RAM and press power it beeps signaling that there is no Ram installed. Maybe some of you have schematics for it and/ or some ideas where could be the problem? I'm quite advanced at soldering but new to laptops so finding the right cause sometimes almost seems impossible, I can change KBC, BGA chips.. I would be really grateful for a cup of knowledge!
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3575
    • slovakia
    Re: Lenovo Thinkpad E30
    memory driver is buld in NB so try to replace it
    • Tomas9t1
      • Apr 2015
      • 41
      • Lithuania
      How about something easier at first? Because laptop detects that there is no Ram if I don't install them and starts beeping, with RAM it runs like with damaged RAM, fan spins a bit, the power LED turns on, HDD spinning, I would say it's pretty similar to bad GPU
      • dj_ricoh
        • 2073
        • uk
        near the ram there are some coils that provide voltage to socket memory ram!
        how much voltage you got there?
        like ktmmotocross said; if the feedback its done by NB you might need to replace the chip.
        maybe maybe the regulators are bad.
        without schematic its very hard to trace. Not impossible but hard
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3575
          • slovakia
          here is schematics
          • Tomas9t1
            • Apr 2015
            • 41
            • Lithuania
            Thank a lot mate!!!!
            • Tomas9t1
              • Apr 2015
              • 41
              • Lithuania
              Can anybody post bios dump? My bios is empty :/ Changed NB, everything is the same...
              • newtothis
                • Mar 2013
                • 1556
                • england
                Ok may be obvious but are you using the same RAM modules your friend bought or different known working RAM?
                • Tomas9t1
                  • Apr 2015
                  • 41
                  • Lithuania
                  Yes I am using tested RAM which are working on other laptop
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Had to check as some people don't! lol
                    • Tomas9t1
                      • Apr 2015
                      • 41
                      • Lithuania
                      I need dump for intel btw my dump is here http://www.4shared.com/file/3y7JqpTHce/e30org.html
                      • Tomas9t1
                        • Apr 2015
                        • 41
                        • Lithuania
                        Can it be CPU?
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Can it be CPU?
                          If it always shows symptom of power, but no video and no bleeps at all.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • Tomas9t1
                            • Apr 2015
                            • 41
                            • Lithuania
                            It beeps only if don't insert RAM and power it on
                            • Tomas9t1
                              • Apr 2015
                              • 41
                              • Lithuania
                              To sum up what I have done so far, tested all caps aruond that area, changed about 20 SODIMMs, change NB to brand new working, where should I look next?
                              • dj_ricoh
                                • 2073
                                • uk
                                BIOS? Back up and write new bios
                                • Tomas9t1
                                  • Apr 2015
                                  • 41
                                  • Lithuania
                                  did a backup uploaded here, can't find new one, found only one but it's for AMD not intel
                                  • dj_ricoh
                                    • 2073
                                    • uk
                                    We got a guru with bios.
                                    He help me to last week.
                                    Upload the old bios.
                                    • dj_ricoh
                                      • 2073
                                      • uk
                                      Did you try a new Cpu?
                                      • Tomas9t1
                                        • Apr 2015
                                        • 41
                                        • Lithuania
                                        it's mounted, so today I will try replacing with a working one, I hate reballing
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
