Toshiba satelite No power
  • razu
    • Jan 2015
    • 218
    • Bangladesh
    Hy my friend
    I have a Toshiba satellite m100 Laptop adapter is 15v 5A...... its power Led continue flickering no 5v, 3v. I change its power Ic Max 8734A still same conditions, power Ic input voltage also flickering(up,down) switching voltage is 13.39v. change pu1 Lm 393 same conditions.............
    Please any one can help me
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Toshiba satelite No power
    razu, normally that happens when there is short somewhere on your mobo. try checking coils if there is shorted against ground.
    • razu
      • Jan 2015
      • 218
      • Bangladesh
      Its not have short any one can see this board before I open and he opened the IO controllar I found its on schematic and thats why its not repairable
      Its solved
      • dj_ricoh
        • 2073
        • uk
        SIO? was bad?
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
          03-31-2024, 02:12 PM
        • ju123
          Toshiba Satellite C50-A won't power down
          by ju123
          Hi guys,
          So, I've been racking my brains on this one.
          I have a Satellite C50-A which I'm repairing for a friend.
          I recently replaced the main board due to failure.
          Following this, absolutely everything works perfectly, except for the fact it won't power down.
          Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
          01-07-2022, 04:40 PM
