Hp 4520s Not powering up white led blinking
  • markopolo
    • Mar 2014
    • 27
    • Slovenia
    Hi everyone!
    I have a problem the HP 4520s that is not powering up.
    I have measured the regulator voltages and they are ok 3,3V and 5V
    Then I have checked the charging chip and everything was ok except the acdetec there should be at least 2.7 V for the chip to detect the main power but there is 0. Then I have checked the resistors capacitors and transistors where the acdetect comes from and all seems to be ok.
    If someone had this problem any suggestion would be apreciated.
    The Main board is H9265-1
  • Ramee
    • Jul 2014
    • 218
    • Israel
    Re: Hp 4520s Not powering up white led blinking
    Flash it
    • smali
      • Sep 2014
      • 287
      • Pakistan
      check the adopter watts may be low and battery may be fully discharge.
      • claudyu07
        Claudyu07
        • May 2014
        • 125
        • Ireland
        How many times it's flashing?
        Hp have error codes
        Check this : http://h20564.www2.hp.com/hpsc/doc/p...rComputerBeeps
        • masud
          • Jul 2011
          • 317
          • Bangladesh
          press and hold the power button without battery and charger for 10 seconds and then try.
          • mesersmith
            • Dec 2014
            • 35
            • România
            Do you have the original HP charger?
            • markopolo
              • Mar 2014
              • 27
              • Slovenia
              Yes I have tried all the suggestions but nothing helped. Except for flashing I didn't flash it yet. Does anybody have a bios dump? And it is flashing instantly.
              • gcomputers
                • Apr 2013
                • 509
                • Albania
                try this, but maybe ati chip problem???
                • crewdog
                  Hp 15-dy2087nr white lights blinking
                  by crewdog
                  Board DAOP5HMB8F REV F
                  Model OPSH
                  No bios battery on board
                  Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
                  Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
                  and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
                  Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
                  10-25-2023, 03:08 PM
                • noipi
                  DELL INSIPRON 14 No power blinking orange/white
                  by noipi
                  i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
                  05-06-2025, 08:08 PM
                • jorpec
                  HP Elitebook 8460p battery led white and blinking orange
                  by jorpec
                  Hello everyone
                  I have this Elitebook that wont turn on, only the battery led is white and blinking orange, does this even without battery.
                  If this is a error code i couldn't find any info about it.
                  Already tested with a another charger, measure the presence on 19v on the 19v rail, checked if there was capacitors in short-circuit
                  Thanks...
                  05-05-2025, 04:39 AM
                • bialag
                  Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                  by bialag
                  I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                  Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                  03-25-2025, 05:56 PM
                • jajo17
                  HP Probook 470 G2 - white blinking - ADP_SIGNAL ?
                  by jajo17
                  Hello, I have this laptop with a bad motherboard. The LED in the socket is blinking white, endless loop. According to the information I found on the internet, this can be caused by several reasons that I am currently investigating.
                  1. Damaged BIOS chip - it seems to be fine, CH341a programmer can read it
                  2. BIOS RTC voltage shorted to ground - it seems to be fine, around 3V
                  3. Damaged adapter identification circuit - I think there is a problem here, but please help explain the function
                  What should be the voltage on ADP_SIGNAL when using a 65W HP adapter? My calculation of the voltage divider comes...
                  02-28-2025, 05:18 AM
