Acer Aspire One D270 Netbook has no Power or Battery charge Indicator
  • Agent24
    I see dead caps
    • Oct 2007
    • 5081
    • New Zealand
    Re: Acer Aspire One D270 Netbook has no Power or Battery charge Indicator
    Originally posted by tfs2015
    red lead on pq41 pins 5,6,7,8 black lead on ground = open
    black lead on pq41 pins 5,6,7,8 red lead on ground = .873 ohms
    this seems correct if PC10, PC91, PC90, PC9 are working correctly
    Yeah that makes sense. With the red lead on ground measuring to BAT-V will give that 0.873 ohms from the body diode in PQ50.
    Have you checked the current sense resistors PR155 and PR133 for open circuit? Should also check PR42,42,44,56 for open or high value.
    -David VanHorn
    • tfs2015
      • Feb 2015
      • 135
      OK, I will check that and report back. Could this also be causing the main power not to come on as well? This is board has multiple issues and just trying to trouble shoot and fix one at a time in the hopes of making it work again. The person who took this machine apart was not very skilled at doing so and they are hoping that I can get it to work for them again.
      Computer and Small electronics troubleshooting and repair
      • Agent24
        I see dead caps
        • Oct 2007
        • 5081
        • New Zealand
        I suspect the battery not getting voltage to charge and the LEDs not coming on stem from the same problem, whatever it is. Seems that something is preventing anything from coming up.
        I can try to help but don't have specific experience in repairing these. I can think of things in general you can check which might be the problem but that's about it.
        Probably one of the other guys here will have a better idea of where to look though.
        -David VanHorn
        • tfs2015
          • Feb 2015
          • 135
          everything looks good that you mentioned.
          is there anything to be bypassed to force the charging circuit to come on?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5081
            • New Zealand
            I don't think you can force the charger on. But the charger IC will have some conditions which need to be met before it will start charging, the datasheet would explain this.
            You may be able to check and see if all these things are satisfied, and if they are not, it may help point in the direction of why.
            It might help to look at the standby power supplies and signals from the EC too, though.
            -David VanHorn
            • tfs2015
              • Feb 2015
              • 135
              thank you for the info I will take a look at it and get back to you
              • meritosari
                • Oct 2010
                • 774
                • Indonesia
                #27
                check voltage pr133 pin 1 & 2
                on pu2
                2
                3
                13
                27
                28
                • tfs2015
                  • Feb 2015
                  • 135
                  check voltages pr133
                  pin 1 19.22 vdc
                  pin 2 19.21 vdc
                  check voltages pu2
                  pin 2 3.87 vdc
                  pin 3 3.19 vdc
                  pin 13 0.00 vdc
                  pin 27 19.16 vdc
                  pin 28 18.88 vdc
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5081
                    • New Zealand
                    #29
                    I think ACOK signal (Pin 13) is not correct, since you have ACIN above 3.2v, according to the datasheet, ACOK should be high (+3v)
                    Check pullup resistor PR59 is not open circuit.
                    If you don't get voltage on either end of PR59 then +3VPCU rail is probably not working.
                    -David VanHorn
                    • tfs2015
                      • Feb 2015
                      • 135
                      PR59 has no voltage on either side so I cause that means +3Vpcu is not working or is open so now where do I go and check? possibly pu3 as I think that supplies 3v/5v power to system.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5081
                        • New Zealand
                        #31
                        Yes PU3 (page 30) is the controller for +3VPCU and also +5VPCU rails.
                        Do you get any voltage at inductors PL4 and PL3?
                        -David VanHorn
                        • tfs2015
                          • Feb 2015
                          • 135
                          PL3 and PL4 no voltage
                          pin 16 PLU3 18.89 vdc
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5081
                            • New Zealand
                            #33
                            Can you list what voltages are on PU3:
                            Pin 8, Pin 13, Pin 17, Pin 18
                            -David VanHorn
                            • tfs2015
                              • Feb 2015
                              • 135
                              Pin 8 3.34 vdc
                              Pin 13 5.23 vdc
                              Pin 17 5.01 vdc
                              Pin 18 3.34 vdc
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5081
                                • New Zealand
                                #35
                                It looks like the VREG5 and VREG3 outputs from PU3 are enabled and OK, but while the switching outputs are also enabled (Pin 18/ENC is above 2v) the main outputs are not running.
                                I think this would imply that PU3 may be bad or there may be a short on +3VPCU or +5VPCU.
                                -David VanHorn
                                • tfs2015
                                  • Feb 2015
                                  • 135
                                  how could I find a short if there was one? first with just battery connected, and then with just ac adapter connected?
                                  Tom
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5081
                                    • New Zealand
                                    #37
                                    No, with battery and power disconnected, measure between PL3 and Ground. Also measure between PL4 and ground. Measure in both directions (swap probes) to be sure.
                                    -David VanHorn
                                    • tfs2015
                                      • Feb 2015
                                      • 135
                                      No short but low resistance Values. Did notice that pc58 and pc46 missing from board.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5081
                                        • New Zealand
                                        #39
                                        Missing as in removed or never there to begin with? Can you post photos of the pads where they would be?
                                        -David VanHorn
                                        • fddizon
                                          • Sep 2011
                                          • 555
                                          • Philippines
                                          #40
                                          TFS2014,
                                          try to locate this ceramic cap. it might be the same faulty part..
                                          see picture attached...
                                          ceramic cap near a coil bottom right red rectangle
                                            Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 05:27 AM
                                            Acer Aspire Aspire One D255 Netbook One Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Aspire One D255 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One D255 boardview and Aspire One D255 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            Acer Aspire A517-52G Netbook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A517-52G Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52G boardview and A517-52G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Aspire...
                                            09-07-2024, 05:20 AM
                                            Acer Aspire A715-42G-R1JW Netbook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A715-42G-R1JW Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A715-42G-R1JW boardview and A715-42G-R1JW schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-07-2024, 05:00 AM
                                            Acer Aspire A515-56G-71JH Netbook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A515-56G-71JH Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-56G-71JH boardview and A515-56G-71JH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 10:00 PM
