Hi need help with this laptop with battery inserted laptop start normal ,charger connected and battery start normal and lights for charging is orange color not sure is that mean that charging battery or not ,without battery wont start .Dont have shematic, charger tested ok work on another samsung laptop .
					Samsung NP3530EC wont start without battery
 Re: Samsung NP3530EC wont start without battery
 Hi
 try to
 bypass the 2nd mosfet in 19v line , if powers on without bat change the 2 mosfets.
 let me know how it workedComment
 Replace second mosfet see picture on post #6 fisrt mosfet pin1,,8 19 v , second mosfet pin 1234 19v pin 5678 0.95 This mosfet from my experience need to replaceComment
 http://www.ebay.com/itm/2pcs-AP-9402...-/360855874322Comment
 NVDC charger configuration...-
							Channel: Common Parts Library - Datasheets
 11-05-2024, 03:28 PM
			ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
 Highly Integrated Narrow VDC Battery Charger for Notebook Computers
 The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
 for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
 Narrow VDC applications where the system power source is
 either the battery pack or the regulated output of the charger.
 This makes the max voltage to the system equal to the max
 battery voltage instead of the max adapter voltage. Operating
 at lower system voltage can improve...-
 11-05-2024, 04:43 PM
			by flat-eartherI have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
 So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
 but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
 So the battery is backfeeding the charger and being drained.
 How can I prevent...
			by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
			by sam_sam_samThe Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
 Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...05-06-2023, 12:17 PM
- Loading...
