sony vaio image problems
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    well got this sony vaio with the board model MBX-217 rev1.0
    this machine was turning on but no image.
    cheked all coils for cores , all seems to be ok , so i gave just a bit of air on the gpu , with the hot air and it started to give image , reballed the gpu (client dont want to swap gpu) well it worked fine , so i assembled the machine tryed to turn on _!_ dam bloody vaio and they attitude .
    disassembled the machine , and always that a lift a bit the board gives image !! i taught well could be a bad grounding issue or something making contact with the board once is on te chassi , but no tryed everything , always that alift a bit the board like making a presure on the board it gives good consume about 1.30 amp and start giving image , if i dont make pressure on board i got 0.17 amp turned ok , but no image .
    for what i know many people have this issues with the sony board , if anyone have taught let me know .
    btw also the place were usually i make pressure on the board and start working ok , is near the SB , so i also lifted and reballed SB and the same shit
    any help will be welcome
    jonathan
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    Re: sony vaio image problems
    well fixed , ISL damaged meanwhile , ISL for cpuvcore . cause bloddy wireless cables that were hiden , and they were touching the board somehow .. found the problem , replaced the ISL , removed the wireless and isolated them well , not working 100%
    after all was gpu problem and i killer the ISL with the bloody wireless cables , well another one ready ,
    next p200 turn on and off after few sec and no image , let see what i found here
    cheers
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • delpiero3
      Sony Vaio SVS MBX-261 board failure
      by delpiero3
      Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
      Nevertheless, let's say, i don't come as a total beginner.
      I have this old laptop, which suit perfectly my needs, with the...
      10-29-2024, 06:16 AM
      Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
      This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
      09-06-2024, 05:27 AM
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
