Lenovo B460E Problem
  • gps31
    • Oct 2012
    • 75
    • india
    Lenovo B460E whenever try to install xp/7/8, i am getting 7B error in both IDE and AHCI mode. Motherboard LB46E
    When using usb boot with winpe no problem and i can read files in hard disk drive.
    Flashed Bios no use.
    pls advice
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Lenovo B460E Problem
    please read this
    http://support.microsoft.com/kb/324103/en-gb
    • gps31
      • Oct 2012
      • 75
      • india
      i also tried with another hdd from the same model B460E, i am getting the same error with 7B but same hdd works in another laptop
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
      • s_specialist
        Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
        by s_specialist
        Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
        07-07-2025, 11:47 AM
      • perzyk23
        Lenovo T580 - LCD Panel problem - error 0288
        by perzyk23
        Good morning,
        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
        10-25-2024, 12:42 AM
      • c.daniel
        Lenovo V310-15IKB weird bios problem...
        by c.daniel
        Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
        sn LR09493E
        MB DAOLV6MB6F0 REV. F
        The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
        Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
        Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
        08-22-2025, 05:39 AM
