ASUS N61JQ won't start
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have problem with this notebook. When is power adapter connected , after press a power button only led around this button once blink and notebook don't turn on. After few pressing power button led stay on , but nothing happens, only black screen.. What you thinking? What is the problem? Is this graphic card problem? I ask you before disassembling.. thanks for answer.
    Denis.
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: ASUS N61JQ won't start
    In these cases, it is usually necessary to verify some voltage on the motherboard (bios ic, Super I / O, 5V and 3V, etc.) and you need to disassembly I assume you have to change ram ...
    After disassembly of the unit and tensions are present it is possible that there is a problem of bios and you can try to reprogram If you have the basic tools (multimetr etc.) I can help if a schematic is on the web.
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      Thanks for answer!
      I disassembly it yesterday and problem is in motherboard. Some component near voltage input connector is bad - I attached a photo. I mean it's a mosfet in SOP8. I don't measure other components, I can find schematic first. Someone have schematic of this notebook?
      • DeniS182
        • Jun 2014
        • 328
        • Slovakia
        can someone help me with this? I found service manual only for model N61JV. I attached this manual here and some screens.
        Second mosfet near this burned-out is 4435BZ and in schematic both mosfets are same. I have 4407A mosfet to replace this burned-out mosfet and I don't sure if this is good replacement? I have to replace both mosfets for same or I can replace only one bad mosfet with 4407A? Thanks for answer !
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          better you clean and desolder/remove burn mosfet first. then check if any short component especially another 4435bz.
          try with ohm red probe to component and black probe to grnd
          its really difficult to read pcb without marking, better way with board view + schematic
          sorry for bad english
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3607
            • slovakia
            what else marking u need to know? u see J8803.
            • DeniS182
              • Jun 2014
              • 328
              • Slovakia
              HI all,
              I replaced burned out mosfet and also second mosfet near this burned out. I used same type as original - 4435 - in schematic are both mosfets same. PCB under burned out mosfet was burned too and I had to connect gate of mosfet with wire - pad was damaged, but I measured where was connected .. Also I replaced 4 shorted ceramic capacitors. After replacing these components I connected motherboard to regulated power supply with current limiting set to 300mA, but it is not working. Without current consumption.
              edit:
              Now I look better to schematic and in there are mosfets drains connected to each other and on PCB are sources connected to each other.. Now I mean I need replace mosfet who I replaced before, with N-channel mosfet. I attached schematic and I don't know where on pcb is the part which I mark ???. Schematic from N61JV is too different. I'm confused now. Can someone help me? Thanks!
              • meritosari
                • Oct 2010
                • 774
                • Indonesia
                try this, its a little different with your project, but i think its can help you.
                • DeniS182
                  • Jun 2014
                  • 328
                  • Slovakia
                  Thanks for it, but i don't know how to open these files?
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    asus tsic
                    • DeniS182
                      • Jun 2014
                      • 328
                      • Slovakia
                      I opened it with this program thanks. This pcb layout is same as in service manual who is attached in fourth post, but not same as my motherboard.. Can I find type of mosfet from this pcb layout in asus tsic? I opened some .dat file in excel, but for example PQ8903 is no type written here. Only values of resistors, capacitors, inductors...
                      edit:
                      I found this motherboard on ebay and I asked the seller what is written on these mosfets and he answered me - 4835gm a3779g and both are identical.
                      • DeniS182
                        • Jun 2014
                        • 328
                        • Slovakia
                        I can't find where is input voltage connected. I measured 19V only on connector. Also I tried to find it with ohm-meter..Connector is good soldered to pcb and input voltage is not elsewhere than in the area marked in the picture. Can someone help with this?
                        • meritosari
                          • Oct 2010
                          • 774
                          • Indonesia
                          i think after dc connector is L6003 & L6004, see my attachment. look like as caps, but a bigger than caps. but be carefull.
                          i'm not a master, so be patient. wait and see if any guy for better suggestion, cause its 19v rail. very dangerous to other component with low volt
                          • DeniS182
                            • Jun 2014
                            • 328
                            • Slovakia
                            Good idea! These are capacitors what I replaced because they were short-circuited ( 0.6ohm) but if these is L6003 & L6004 it's makes sense. Thanks and I wait for other answer.
                            • DeniS182
                              • Jun 2014
                              • 328
                              • Slovakia
                              Because no answers here I tried jumped this L6003,l6004 and now it doing the same thing as in first post. Only all leds blinks once.. Can someone help me? I will measure what you need to help me. Thank you.
                              • DeniS182
                                • Jun 2014
                                • 328
                                • Slovakia
                                Without CPU motherboard stay on..
                                • meritosari
                                  • Oct 2010
                                  • 774
                                  • Indonesia
                                  without adapter and battery, try to measure the resistance in all large coil.
                                  • DeniS182
                                    • Jun 2014
                                    • 328
                                    • Slovakia
                                    0.3-0.4R on all
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      You're measuring wrong then. You should measure the resistance between one end of the coil (doesn't matter which one) and ground, which would be one of the mounting holes of the motherboard.
                                      A working TV? How boring!
                                      • DeniS182
                                        • Jun 2014
                                        • 328
                                        • Slovakia
                                        Of course , sorry. I marked two coils with low resistance on picture. Only on 1 coil I measured stable resistance , near cpu - 10-12 ohm. Others are not measurable, often changing the value on lcd.
                                        • AtelierRepa
                                          ASUS X712JA problem
                                          by AtelierRepa
                                          I have a problem with the bios, let me explain.
                                          With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                                          I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                                          My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                                          The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                                          06-15-2024, 04:33 AM
                                        • Dobrowol
                                          Asus GA402RK keyboard and kb backlight problem
                                          by Dobrowol
                                          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                          04-28-2025, 04:30 PM
                                          ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                          This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                          09-07-2024, 02:50 AM
                                          ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
