Can anybody tell me the location of eeprom(bios chip)of hp 6930p and with intel gpu..THX advance!
					HP 6930p need some help
			Can someone please direct me to the location of the BIOS? I've attached an image of the motherboard. Would like someone to point out the location or if I do indeed need to pull the motherboard if it's on the other side. Thank you....-
							Channel: BIOS Requests ONLY!
			by vikivngpls help guys..This laptop powers up but nothing on screen..have tried different ram ..it may be the bios? can someone point out the location of the chip pls.?...-
			by tarikabakHello, one of the vrams of my palit rtx 3060 model graphics card is showing as faulty. I will replace the faulty vram with a new one, but I could not find out the locations of the vrams. Does anyone know the location map such as a0, a1, b0, b1?
 mats version 455.127. Testing GA104 with 20 MB of memory starting with 0 MB.
 Memory Errors on
 Read Error Count: 0
 Write Error Count: 410022
 Unknown Error Count: 0
 === MEMORY ERRORS BY SUBPARTITION ===
 SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
 ------- ----------- ------------ ------------...1 Photo
			My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
			by DELLS DEALSHello Everyone I hope you are all okay I'm just looking for the location of the bios on the hp probook 445 g9 please if you could help id be very grateful I brought a flasher that clips on to the chip I just can't find the chip unless I ain't installed the drivers for the flasher properly. Any help would be brilliant if you have a diagram that would be great. I Look forward to hearing from you many thanks Dom Noonan-
 10-29-2024, 05:04 AM
- Loading...
