Hello Everyone I hope you are all okay I'm just looking for the location of the bios on the hp probook 445 g9 please if you could help id be very grateful I brought a flasher that clips on to the chip I just can't find the chip unless I ain't installed the drivers for the flasher properly. Any help would be brilliant if you have a diagram that would be great. I Look forward to hearing from you many thanks Dom Noonan
Hp probook 445 G9 bios location
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
Channel: BIOS Requests ONLY!
07-02-2025, 02:31 PM -
by macabookHello everyone,
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
