asus n53j weird problem.
  • luke10050
    • Mar 2013
    • 209
    I have an asus n53j (first gen i5, nvidia gt425m) that initially would not turn on at all, and on the one occasion it did work it froze in bios after about 30 seconds. I had the random idea to solder a 470uF cap near the cpu as there were a large amount of blank spaces for capacitors and the system now boots reliably and is rather bullrtproof. However, if an intensive task is run for more than ~2 minutes, be it a game like skyrim or something like 3dmark or prime95, the laptop will randomly shut down and refuse to start for about 30 mins (as if something is cooling down) and then will work normally. It is not the cpu or gpu as under all conditions they idle at around 80 degrees max. Tested the ram and it seems fine too. The results from the capacitor lead me to believe it is a power related issue as there are a few FET's missing from thr board and a few unpopulated capacitor pads.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: asus n53j weird problem.
    u did not remove the bad cap so there are some problems
    • luke10050
      • Mar 2013
      • 209
      Most caps are tantulum, from what i understand they dont exactly go bad, plus, its more like something is heating up and going out on some kind of thermal shutdown, and if they do go bad they generally do so in quite a visible way
      • hazardus
        • Apr 2014
        • 105
        Not always. I'd change all tantalum caps around the cpu.
        • luke10050
          • Mar 2013
          • 209
          Okay, i'll give it a go then, might also see if i can get a thermal camera... depends on my luck
          • AtelierRepa
            ASUS X712JA problem
            by AtelierRepa
            I have a problem with the bios, let me explain.
            With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
            I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
            My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
            The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
            06-15-2024, 04:33 AM
          • lukkihapsi
            Asus Vivobook X515JA Weird Boot Issue
            by lukkihapsi
            Asus Vivobook X515JA Laptop
            Issue :
            Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
            Tried :
            Cleaned inside for dust, applied fresh thermal paste. No Change!
            Removed keyboard, Trackpad, fingerprint sensor. No Change!
            Removed Internal SSD. No Change!
            Updated BIOS to latest version. No Change!
            Removed battery and pressing power button for 1 minute. No Change!
            Weird Part :
            Upon turning laptop ON, screen lights up - stays black,
            I...
            07-07-2025, 12:07 PM
          • Dobrowol
            Asus GA402RK keyboard and kb backlight problem
            by Dobrowol
            Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
            04-28-2025, 04:30 PM
          • RotVik
            ASUS PRIME B550M-A AC weird behavior
            by RotVik
            Hello, I need a little help
            I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
            I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...
            05-01-2025, 04:59 PM
            ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
            This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
            09-07-2024, 02:50 AM
