MBX247 water damage
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    MBX247 water damage
    Hi I need some help with this one I have a Sony Motherboard MBX-247 it has very small amount of water/liquid damage. on the KBC and few surrounding components. I replaced the KBC and lifted the coil PL13 on the 3.3v line as theres also a short farther down on the +3vpcu line . But fir the moment I am trying to get 3.3v from pu9 (PM6686) but not getting output. I have replace this chip with new one also.
    So I get
    Pin1 ref 1.8v
    Pin2 Ton 0v
    pin3 vin 4.9v
    pin4 enldo 4.9v
    pin6 vin 19v
    pin7 ldo 4.9v
    pin27 en1 4.9v
    Any ideas why Im not getting 3.3v out?
  • dj_ricoh
    • 2073
    • uk
    Re: MBX247 water damage
    every thing its ok on ISL88731?
    • Bisketti
      • Oct 2013
      • 252
      • Ireland
      Looks ok , is there anythin in particular I should be looking at. Im stumped .I cant figure out why there no 3.3v output
      • hazardus
        • Apr 2014
        • 105
        If you have a scope check the signal on Pin 23 and 25,26 at PU9.
        • Bisketti
          • Oct 2013
          • 252
          • Ireland
          Thanks for the input. So basically the pu9 3.3v wont output until the coil is in place due to the feedback loop I presume because I re soldered PL13 and then then bench supply returned to switching on current limit and going back into the loop. I then removed pq45 and pq44 and the 3.3v retuened to pl13. bo if I now put 3.3v into either of the +3v (pq45 pin1) or +3v_s5(pq44 pin 4) the the overcurrent kicks in. So basically Im looking for a fault common to both lines.
          • Bisketti
            • Oct 2013
            • 252
            • Ireland
            I have also found that pl8 (+1.05v) has a short on that line also. When I lift one side of Pl8 the short on the regulator side isnot prsent so is further downstream on the +1.05v line.
            • Ugur87
              MacBook Air M4 A3240 Brand New Water Damage no Image
              by Ugur87
              I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
              08-28-2025, 01:09 PM
            • edugimeno
              Stagg sms12p audio amp has water damage
              by edugimeno
              Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
              I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
              There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
              There is only one signal wire connecting the first boards...
              05-24-2025, 06:00 AM
            • Joel Ohana
              Lenovo IdeaPad 3 15IAU7 that suffered water damage
              by Joel Ohana
              I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
              Symptoms:
              • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
              • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
              What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
              03-06-2025, 11:25 AM
            • abajor
              A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
              by abajor
              Like title says A2141 came in with Water Damage, customer desperately wants the data.
              The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
              I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
              That said after cleaning up the...
              12-21-2024, 07:16 PM
            • s_henya
              Macbook Air A3114 5V 0.0A after water damage
              by s_henya
              Hi Mac experts :-)
              Im usually not getting too many Mac logic boards repairs, (mostly PC laptops)
              This Mac isn't powering on not boosting to 20v, stays at 5v with 0.0Amps.
              Took out the board and it suffered some water damage, see attached pics.
              All cleaned with IPA but due to long time with corrosion something already got shorted...
              any advice on the below:?
              1. Looking for relatively safe location for voltage injection as all of the caps around that area has 0.0ohms resistance.
              I tried injecting 0.5v on one of the caps...
              08-25-2025, 01:09 PM
