dell d830 graific problem.
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Ok , received this machines somethime ago . we had seen gpu wa faulty , since was not displaying image , and after giving 15 second of heat on the center of the chip it start giving image . so we talked with client for chip replacement , and since he had urgence , we made a good reflow on is machine for it can work with the machine until chips arrive . well 2 days before chip arrive machine not giving image again , and we mentioned to him , well chip is almost here , leave machine here and we will replace it very soon . chip arrived , we inserted the new chip , all seems good , passed all test .
    client started using it , and it worked good for maybe 3 weeks , it came in saturday , mentioning machine was not displaying image , only somethimes and will the tipical problem of VRAMS ( red lines ) . i thinked could be vram gave a bit of heat on all of them .. and internal display not displying anything now . only external and with the suposed red lines , and some flicker..
    lifted all vrams , and reball them but the same , so i replaced with another vrams , but still same issue as well .dead chip ??? but dam is a new chip working for a month .
  • khaahk
    • Dec 2013
    • 753
    • Estonia
    Re: dell d830 graific problem.
    ebay "NEW" is not always new. Which chip, what price, what seller, was there signs of previous usage? Underside scratches, signs of old glue at sides?
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      no this supplyer is trusted for sure , never had any problem with GOLDENCHIPSET supplyer for a longgggg time , always well packaged in original package of distribution and smell and look like brand new .
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • ed1i
        Dell Inspion 7610 bios chip
        by ed1i
        Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
        01-16-2025, 02:14 PM
      • ezenia
        Dell G3 3579 BIOS chip ID
        by ezenia
        I bought a Dell G3 3579 eBay. The fault was not mentioned and it did not come with charger. Before trying to power off battery, I did some basic checks on the coils (in resistance mode) to see if there was any short. None were reading short. Decided to power the board to see if anything happened. The keyboard backlight came on. About 5 seconds later, the fans begin spinning at max speed. The white LED comes on at this time, stays solid for a bit and goes off. Fans continue to spin at max. Display is black (no backlight). If I hold down power button, board goes off. I did give...
        06-16-2025, 08:07 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • al_b0sni
        Dell Optiplex 5000 8fc8 with chip W25Q128JVSN
        by al_b0sni
        Hey, i bought a Dell Optiplex 5000 8fc8 with chip W25Q128JVSN.
        I also used the CH341A programmer but my usb cable (i didnt attach it directly into the pc, i used a cable between) was corrupted. So i made a dump. Then i removed the password but unfortunately the dump had a loose contact so it was corrupted. And i've also overwrited the chip and now i dont have any dump anymore.
        Can someone help me? I am stuck since hours and i cannot find any bin file anywhere.
        I tried to extract the EXE for BIOS installation from dell and also the rcv file but i didn't manage to do that....
        06-18-2025, 03:42 PM
