Macbook Pro 13" A1278 (Mid 2012) no signs of life
  • pearman
    • Jul 2013
    • 15
    • Norway
    I am a novice (or the step just before) trying to troubleshoot a logic board that shows no signs of liquid damage or other abuse, but it will not start. The magsafe charger does not light up at all.
    I know that the charger is OK, and that the magsafe-board is OK.
    I have the board schematics as well as well as a brd layout file.
    I have probed for voltage and it seems my problem starts with the U7090 / LT3470A.
    Here are some probed voltages from that chip and near by;
    Code:
    Pin06 PPCHGR_DCIN_D_R = 0.00v (Probe 1019)
    Pin04 P5V5G3H_SW = 0.00v (probe 1090)
    Pin02 PP5V5_CHGR_VDDP = 0.00v (probe 1037)
    PPDCIN_G3H_INRUSH_FET = 18.5v (probe 1051)
    PPCHGR_DCIN_D = 18.63v (probe 212)
    PPCHGR_DCIN_D_R = 0.0v (probe 1019)
    R7093 = infinite, fail?
    R7005 = 20 ohm
    C7005 = tested ok
    Could this be the cause of my problems, or am I on the wrong path?
    I have some more probe-points if that would help;
    Code:
    Power rails
    PPBUS_G3H = 12.27v (measured on PPBUS_S5_HS_OTHER_ISNS)
    PPBUS_S0_LCDBKLT_FUSED = 12.27v (F9700)
    PPBUS_S5_FWPWRSW = 12.27v (probe 1345)
    PPBUS_S0_VSENSE = 0.00v (probe 1324)
    PPVIN_SW_T29BST = 0.0v (measured on Probe 1249)
    PPBUS_S5_HS_COMPUTING_ISNS = 12.27v (Probe 877)
    PPVIN_S5_HS_OTHER_ISNS = 12.27v (Probe 865)
    BRD file: https://www.dropbox.com/s/d3ejh90yds...115-B.brd?dl=0
    PDF schematics:
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Macbook Pro 13" A1278 (Mid 2012) no signs of life
    u7000 pin probe
    • pearman
      • Jul 2013
      • 15
      • Norway
      Code:
      U7000 / ISL6259HRTZCHGR_ACIN = 4.46v
      Pin05 CHGR_ICOMP = 1.13v (probe 175)
      Pin01 CHGR_AGATE = 0v (probe 200)
      Pin28 CHGR_CSI_P = 18.43 (probe 201)
      Pin19 PP5V1_CHGR_VDD = 5.08v (measured on R7001)
      Pin20 PP5V1_CHGR_VDDP = 5.07V (probe 202)
      Pin03 CHGR_ACIN = 4.46v (probe 176)
      Pin02 PPCHGR_DCIN = 18.54v (measured on C7005)
      Anymore pins interesting on the U7000?
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        on white fuse near battery connector you have 12.5 volt ?
        on power on button for smc bypass you dont have 3.42 g3hot volts?
        measure volt in on ld3470 all 6 pins.
        on u7000 u have to check all pins.
        • pearman
          • Jul 2013
          • 15
          • Norway
          18.9v (85W charger)
          on power on button for smc bypass you dont have 3.42 g3hot volts?.
          3.46V (probe 882, SMC_ONOFF_L)
          Do you mean LT3470 / U7090?
          Code:
          U7090 / LT3470A
          Pin01 P5V5G3H_FB = 0.00v
          Pin03 P5V5G3H_BOOST = 0.00v
          Pin06/07/08 PPCHGR_DCIN_D_R = 0.00v (Probe 1019)
          Code:
          U7000 / ISL6259HRTZ
          Pin01 = 0v (probe 200) CHGR_AGATE
          Pin02 = 18.54v (measured on C7005) PPCHGR_DCIN
          Pin03 = 4.46v (probe 176) CHGR_ACIN
          Pin05 = 1.13v (probe 175) CHGR_ICOMP
          Pin06 = 3.49v (measured on R7012) CHGR_CELL
          Pin07 = 0.80v (probe 153) CHGR_VCOMP
          Pin08 = 2.05v (measured on R7016) CHGR_VNEG
          Pin09 = 0.04v (probe 154) CHGR_AMON
          Pin10 = 3.48v (probe 962) SMBUS_SMC_5_G3_SDA
          Pin11 = 3.49v (probe 1044) SMBUS_SMC_5_G3_SCL
          Pin12 = 3.49v (probe 155) PP3V42_G3H
          Pin13 = 3.18v (measured on R7000) CHGR_RST_L
          Pin14 = 2.38v (probe 1018) SMC_BC_ACOK
          Pin15 = 0.07v (probe 157) CHGR_BMON
          Pin16 = 11.45v (probe 156) CHGR_BGATE
          Pin17 = 12.27v (C7050) CHGR_CSO_N
          Pin18 = 12.28v (C7050) CHGR_CSO_P
          Pin19 = 5.08v (measured on R7001) PP5V1_CHGR_VDD
          Pin20 = 5.07V (probe 202) PP5V1_CHGR_VDDP
          Pin21 = 0.18v (probe 1036) CHGR_LGATE
          Pin22 = GND
          Pin23 = 11.84v (probe 1045) CHGR_PHASE
          Pin24 = 11.92 (probe 1034) CHGR_UGATE
          Pin25 = 16.01v (probe 214) CHGR_BOOT
          Pin26 = 16.30v (probe 1050) CHGR_SGATE
          Pin27 = 18.43 (C2070 ) CHGR_CSI_N
          Pin28 CHGR_CSI_P = 18.43 (probe 201) CHGR_CSI_P
          Btw; in all measures battery is not connected, only fan and magsafeboard+charger.
          Last edited by pearman; 10-10-2014, 03:10 PM. Reason: Added info about battery connected
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            ok, check voltage on F7040
            then check voltage on U6990
            • pearman
              • Jul 2013
              • 15
              • Norway
              Code:
              F7040 = 12.27v both sides (PPBUS_G3H probe 1345, PPVBAT_G3H_CHGR_REG probe 211)
              Code:
              U6990 / PM6640
              Pin01 = NC
              Pin02 = 3.82v (probe 1131) P3V42G3H_FB
              Pin03 = 9.37v (probe 328) P3V42G3H_TON
              Pin04 = 18.60v (probe 220) PPVIN_G3H_P3V42G3H
              Pin05 = GND
              Pin06 = 3.47v (probe 219) P3V42G3H_SW
              Pin07 = 18.60v (probe 220) PPVIN_G3H_P3V42G3H
              Pin08 = 3.82v (probe 1131) P3V42G3H_FB
              Pin09 = 3.49v (probe 155) PP3V42_G3H
              Pin10 = 3.30v (probe 323) P3V42G3H_REF3
              It seems like after a few minutes, voltage disappeared on PP3V42_G3H_REG. Restored by re-connecting magsafe..
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                all voltage seems ok, but you said that no green light on magsafe?
                • pearman
                  • Jul 2013
                  • 15
                  • Norway
                  Yep, magsafe light is off. Should U7200 be off? (no enable on pin13)
                  It seems that way if I read page 73 correctly..
                  Code:
                  U7200 / TPS51125
                  Pin01 = 0.0v (probe 890) P5VS3_ENTRIP
                  Pin02 = 0.0v (measured on R7267) P5VS3_VFB
                  Pin03 = 0.0v (probe 874) P5VP3V3_VREF
                  Pin04 = 0.0v (probe 881) P5VP3V3_REG3
                  Pin05 = 0.01v (measured on R7269) P3V3S5_VFB
                  Pin06 = 0.0v (probe 889) P3V3S5_ENTRIP
                  Pin07 = 0.01v (pin7) P3V3S5_VO2
                  Pin08 = 0.0v (probe 881) P5VP3V3_REG3
                  Pin09 = 0.0v (probe 880) P3V3S5_VBST
                  Pin10 = 0.01v (probe 906) P3V3S5_DRVH
                  Pin11 = 0.01v (probe 923) P3V3S5_LL
                  Pin12 = 0.0v (probe 873) P3V3ST_DRVL
                  Pin13 = 0.3v (measured on R7273) 5V3V3_REG_EN
                  Pin14 = 0.0v (probe 874) P5VP3V3_VREF
                  Pin15 = GND
                  Pin16 = 12.28v(probe 865) PPBUS_S5_HS_OTHER_ISNS
                  Pin17 = 0.0v (probe 866) PP5V_S5
                  Pin18 = NC
                  Pin19 = 0.0v (probe 1433) P5VS3_DRVL
                  Pin20 = 0.0v (probe 875) P5VS3_LL
                  Pin21 = 0.0v (measured on Q7260/4) P5VS3_DRVH
                  Pin22 = 0.0v (measured on R7260) P5VS3_VBST
                  Pin23 = 0.0v (probe 430) P5V3V3_PGOOD
                  Pin24 = 0.0v (probe 891) P5VS3_VO1
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    check q7221, q7220,
                    but because magsafe green light is off, something must be bad in power circuit.
                    • pearman
                      • Jul 2013
                      • 15
                      • Norway
                      check q7221
                      Code:
                      Q7221 / SSM6N37FEAPE
                      Pin01 GND
                      Pin02 3.27v (probe 1520) P5VS3_EN_L
                      Pin03 0.0v (probe 889) P3VS5_ENTRIP
                      Pin04 GND
                      Pin05 3.32v (probe 904) P3V3S5_EN_L
                      Pin06 0.0v (probe 890) P5VS3_ENTRIP
                      check q7220.
                      Code:
                      Q7220 / RJK0216DPA
                      Pin01 0.0v
                      Pin02 GND
                      Pin03 GND
                      Pin04 GND
                      Pin05 0.01
                      Pin06 12.28
                      Pin07 12.28
                      Pin08 12.28
                      Leftside,
                      L1 0.01
                      L2 0.01
                      L3 12.28v
                      Rightside,
                      R1 0.01
                      R2 0.01
                      R3 12.28v
                      The BRD doesnt match pinout for this one?
                      • dellxps15
                        • Feb 2014
                        • 1598
                        • italy
                        check u7200 if some pin is shorted
                        edit: look q7220 dot for pin 1 start.... pin 5 should be 1 going on side by side.
                        edit: on that page, one dude have the exact same issue as you.
                        http://forums.macrumors.com/showthread.php?t=1628993
                        post number 12.
                        • pearman
                          • Jul 2013
                          • 15
                          • Norway
                          U7200:
                          Nothing shorted to GND at least, except Pin15.
                          Interesting post there. I checked the area around U5010 and there is some residue visible with microscope.
                          I wasnt made aware the board had liquid damage but this sure looks like it, so I'm going to give it a good cleaning.
                          U5010-area:
                          (I missed this checking with magnifier..)
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            check also u7941 volts.
                            • pearman
                              • Jul 2013
                              • 15
                              • Norway
                              Code:
                              U7941 / SLG4AP012
                              Pin01 3.49v (probe 155) PP3V42_G3H
                              Pin02 0.0v (probe 1233) SMC_PM_G2_EN
                              Pin03 0.0v (probe 872) P5V3V3_REG_EN
                              Pin04 3.32v (probe 324) P3V3S5_EN_L_R
                              Pin05 GND
                              Pin06 0.01v (probe 1480) PP3V3_S5
                              Pin07 0.0v (probe 1189) S5PGOOD_DLY
                              Pin08 0.0v (probe 327) S5_PWRGD
                              • pearman
                                • Jul 2013
                                • 15
                                • Norway
                                Ok so I checked
                                Code:
                                U5010 / SN0903048
                                Pin01 3.49v PPV3V42_G3H
                                Pin02 GND
                                Pin03 3.49v PP3V42_G3H
                                Pin04 1.0v SMC_MANUAL_RST_L
                                Pin05 3.18v SMC_RESET_L
                                Pin06 3.33v SMC_TPAD_RST_L
                                Pin07 3.46v SMC_ONOFF_L
                                Pin08 3.30v PP3V3_S5_AVREF_SMC
                                And it seems to generate SMC_RESET_L correctly, to SMC U4900?
                                But from U4900 there is no SMC_PM_G2_EN, which is why it doesnt power on?
                                Measured from U4900 and it's giving power on:
                                PP3V3_S5_AVREF_SMC 3.30v
                                PP1V2_S5_SMC_VDDC 1.21v
                                PP3V3_S5_SMC_VDDA 3.49v
                                Code:
                                Q5490
                                Pin01 0.0v
                                Pin02 0.0v
                                Pin03 0.0v
                                Pin04 18.95
                                Pin05 17.2
                                Pin06 15.7
                                • dellxps15
                                  • Feb 2014
                                  • 1598
                                  • italy
                                  with multimeter in diode mode, or for check short, look if you have some short at some coil.
                                  im still learning macbook power sequence , problem looks like on u7200 and 3.3volt enable, but that no green light on magsafe is a bad thing. try also disconnect bil cable (battery indicator cable)
                                  • pearman
                                    • Jul 2013
                                    • 15
                                    • Norway
                                    If you check here;
                                    It seems like the signal P5V3V3_REG_EN is from signal SMC_PM_G2_EN (which is 0). P3V3S5_EN_L_R is inverted SMC_PM_G2_EN, and voltage here is good, so I think U7200 is good, but simply not getting the right signals from U7941?
                                    U7200 enable (P5V3V3_REG_EN) comes directly from SMC_PM_G2_EN
                                    Bil-flex/board is disconnected. Only charger/fan connected.
                                    • dellxps15
                                      • Feb 2014
                                      • 1598
                                      • italy
                                      5v is on after pressing power botton, so p5v3.3 should be ok when 0v.
                                      problem is no 3.3 volt on u7200 and on pin 4 of u7941 u have 3.3 volt... but no in pin 3 and no 1.3volt on pin 8.
                                      no short on u7941 pins (except pins 5 and 9) ?
                                      if no greenlight means smc is not happy with some voltage, and that s5pgood should be ok and not 0v.
                                      • pearman
                                        • Jul 2013
                                        • 15
                                        • Norway
                                        No shorts on U7941, except GND then
                                        What about previous chip U7090, does it not seem suspicious that R7093 is infinite?
                                        Picture of R7093 pads?
                                        • Rezendes
                                          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                          by Rezendes
                                          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                          05-10-2024, 02:18 PM
                                        • mohammed mohan
                                          For the benefit of those who need it Apple MacBook Pro A1278 2012
                                          by mohammed mohan
                                          Apple MacBook Pro A1278 2012...
                                          06-25-2022, 05:55 AM
                                        • Smudger17
                                          MacBook mid 2012 A1278 fan connector Pads Missing
                                          by Smudger17
                                          I have an A1278 mid 2012 logic board number 820-3115-B and I have lifted the pads from the fan connector. As I don't have access to another laptop I can't view the board view file. Could someone please tell me where I have to jump the wires to please.
                                          03-25-2021, 04:59 PM
                                        • howardc64
                                          Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
                                          by howardc64
                                          Samsung have been using this style LED connector for few years now
                                          Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
                                          The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
                                          10-12-2025, 08:13 PM
                                        • perfm2
                                          Wson8 spring pin probe WORKS
                                          by perfm2
                                          I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
                                          I recently ordered one to give it a shot and it actually worked quite well.
                                          The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
                                          I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
                                          This aided greatly in allowing the probe to stay in place...
                                          03-30-2023, 11:19 AM
