Sony Vaio PCG 7G1M
  • neuron
    • Feb 2013
    • 126
    • Portugal
    Sony Vaio PCG 7G1M
    I have - Sony Vaio MODEL: PCG 7G1M
    SERVICE TAG C3LM267E
    We apply Power:
    Power Led ON
    Battery Led ON
    Disk Led ON
    WLAN Led I can switch ON and OFF
    The three LEDs (Num, Caps, Scroll) near Power Button and S1, S2 always ON
    No display (BIOS...) , no sound ...
    Nothing ...
    Please your advice.
    Thank,
    Neuron
  • lefos
    • Nov 2013
    • 321
    • Greece
    Re: Sony Vaio PCG 7G1M
    Hello, check firstly other ram memory. Then try to reflow slightly the gpu or the Southbridge.
    • neuron
      • Feb 2013
      • 126
      • Portugal
      Thank you for the info.
      I will change several RAM ... any problem with the pins?
      " ... slightly the gpu or the Southbridge ... "
      Total or slightly ... explain please.
      Thank,
      Neuron
      • highpulse
        i hate HP
        • May 2013
        • 1489
        • portugal
        he means that you don't need to try several rams , just test one you know is good , or with a rubber clean well the contact of your ram first.
        if nothing happen , then with a hot air solder station (small ones usually that havve also a solder iron . apply on the die of the chip around 150 degrees for some 15 seconds. then let it cool and then try again to see if there is image.. but first before giving heat on the GPU try the external VGA first (maybe the screen is dead ...>then go for the gpu if there is nothing on external.
        • neuron
          • Feb 2013
          • 126
          • Portugal
          GPU, VGA OR Southbridge -> references .... Samsung TI ...?
          • tiak
            • Sep 2013
            • 50
            • Iran
            agree with "highpulse"
            Check with RGB port and see you have image on external monitor or not?
            If you have image on monitor then it means you have disconnected pin on GPU or your Laptop lcd is dead
            goodluck
            • neuron
              • Feb 2013
              • 126
              • Portugal
              goodluck
              Thank you,
              Ram in slot.
              Connect the Display ... and "Check your cable ....." on screen.
              Power on and the same msg.
              With other Laptops ... the screen get black when we connect ... and with power on ... image on screen.
              Regards,
              Neuron
              • tiak
                • Sep 2013
                • 50
                • Iran
                Ok,
                1- Check cpu voltage
                2- Check chips temperature
                3- Check smd caps on and around chips to find any shorted cap
                4- Turn on laptop and push over the chips (specialy GPU and northbridge) to see image come on screen or not
                Tell me results and I try to help you more
                Goodluck
                • hazardus
                  • Apr 2014
                  • 105
                  tiak:
                  How should he check shorted caps?
                  • tiak
                    • Sep 2013
                    • 50
                    • Iran
                    Hi,very easily! just with a multimeter!
                    I think person who want to repaire a notebook or any electronic board should know a few about electronic and how to test a capacitor,resistance and ...
                    However,he could set multimeter to diod test,one prob on a side of cap and another prob on other side,if multimeter show zero then its Probably shorted cap for be sure he must check that outside of board.(or test both side of a cap with GND on board,if both side shown zero then Probably it is a shorted cap...)
                    • neuron
                      • Feb 2013
                      • 126
                      • Portugal
                      A - Section
                      Ok,
                      B - Section:
                      Goodluck
                      Thank you,
                      I have ESR, LCR - ST5 and many other eq.
                      " 1- Check cpu voltage"
                      But: Connect the CRT, LED, PLASMA ... and
                      With other laptops and tower ... if you connect external monitor to board ... no more "Check your cable. ..."
                      Something is wrong with GPU or around ....
                      "2- Check chips temperature"
                      With an IR meter (Fluke ) ? freeze can?
                      Any procedure ?
                      "3- Check smd caps on and around chips to find any shorted cap"
                      With DMM you explain in B Section ... with the ESR ... i can get 0 Ohm in circuit.
                      "4- Turn on laptop and push over the chips (specialy GPU and northbridge) to see image come on screen or not
                      Tell me results and I try to help you more"
                      Push ... tap ... click ?
                      THANK YOU VERY MUCH FOR YOUR HELP AND INFO,
                      Neuron
                      • tiak
                        • Sep 2013
                        • 50
                        • Iran
                        Hi,your welcome;
                        1- Check cpu voltage form fet's (mosfet's) Drain pin around cpu suket with voltmeter to determind you have cpu voltage or not (it must be in a range about 0.9 v up to 1.3 v)
                        2- You can check that with your fingers,they shouldn't be hot and burn your finger (but be careful please)
                        3- ESR not bad,but i think diod test is better,but if you couldn't find 0 ohm with ESR ,it's ok
                        4-Push over chips to determind those haven't disconnected pin
                        (I think you must finally program the bios ic,but first do those tests)
                        Goodluck
                        • neuron
                          • Feb 2013
                          • 126
                          • Portugal
                          Hi,your welcome;
                          Goodluck
                          Thank you,
                          "... must finally program the bios ic ... " Why?
                          I will test and report .......
                          • Claudio Silva
                            • Feb 2013
                            • 94
                            • Portugal
                            Post the schematic, so i can try to help
                            • tiak
                              • Sep 2013
                              • 50
                              • Iran
                              I'm sorry my friend,I dont know how I saw "can't find" when you wrote "... i can get 0 Ohm in circuit." maybe I was tired!!
                              you mean you find 0 Ohm? if yes,where and which cap?
                              Cause I think you did't find any shorted cap then I think the Probably problem is bios and so I wrote "(I think you must finally program the bios ic,but first do those tests)"
                              • tiak
                                • Sep 2013
                                • 50
                                • Iran
                                Hi my friend,any result?!
                                • neuron
                                  • Feb 2013
                                  • 126
                                  • Portugal
                                  Claudio Silva:
                                  "Post the schematic, so i can try to help"
                                  Searched ... but no file ... Please can you provide or any member???
                                  At moment I'm out of city ... no access Laptop
                                  ESR give 0,00 Ohm ... good cap ... or could be a short cap.
                                  With a DMM we retest the cap and if 0 Ohm -> is short.
                                  If we retest and high Ohm good cap.
                                  Best Regards,
                                  Neuron
                                    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 05:27 AM
                                    Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                    This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                    Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                    This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                    This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  • Carlos#2003%
                                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                    by Carlos#2003%
                                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                    02-15-2024, 07:52 PM
