Dual MOSFET FDMS3600S replacement
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    Does anybody know what the FDMS3600S can be replace with? I dont have any and need to find some replacement on ebay as this one is not avaliable.
  • tw2005
    • Oct 2011
    • 6458
    Re: Dual MOSFET FDMS3600S replacement
    http://alltransistors.com/mosfet/crs...6&caps=Power56
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 343
      • India
      when ever i need this kind of mosfet i use to make it adding two mosfet
      • Ramee
        • Jul 2014
        • 218
        • Israel
        If you like Chinese product, you can get it from here
        http://www.aliexpress.com/item/FDMS3...866550399.html
        • sopik78
          • Nov 2013
          • 517
          • Czech Republic
          I have never used that aliexpress, is it safe? There is no option on ebay at this time.
          • diif
            • Feb 2014
            • 6978
            • England
            I've used Aliexpress for a while now, I haven't bought loads of ICs but the ones i have bought have been fine. Check the ratings and sales (a little like ebay). There are quite a few fakes on the site, but you do get the opportunity to leave feedback.
            • Ramee
              • Jul 2014
              • 218
              • Israel
              AliExpress is good, but i can use only Visa card, can't use Paypal, only on ebay.
              Lilke diif said, look for ratings, if the ratings below 98% i don't buy from that store.
              • DoOm86
                Dual mosfet replacement help
                by DoOm86
                Hello.
                I have a notebook with a shorted mosfet, it's a E6930 GA8125.
                It seems to be a 30V dual asymmetric N-channel AlphaMos.
                Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
                And here is where I need help!
                It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
                I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
                Thanks!...
                10-31-2023, 12:03 PM
              • jm942
                Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                by jm942
                My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                I did voltage injection on the cpu with 0.7V and i have a current...
                07-11-2024, 05:11 AM
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
              • String2016
                SMD MOSFET REPLACEMENT
                by String2016
                Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
                01-23-2025, 06:35 PM
              • String2016
                by String2016
                i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
                12-15-2024, 05:31 AM
