Have one X401a not working. have burned mosfet behind PJP8301. it have not marking/damn asus/. Have anybody schematic or schematic of same power circuit?
asus x401a not work. burned mosfet
Hey guys,
i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
Now i thought something... -
by hollox123Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
1. Laptop keyboard doesn't work
2. The backlight on the laptop keyboard doesn't work
3. The x2 side LEDs (red) on the laptop don't work
The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
But I am strongly aiming that it is somehow a BIOS-related problem,... -
by ScotchmistI have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
I have removed the mosfet and can run the laptop no problem
The MOSFET is FDPC5018SG
Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
Thanks -
by MicroSMD LabThe board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the... -
by Wolf1977hi
in a welding machine i had a mosfet and four components wich connect with it burned
i ordered all the damaged components and replace it but when i put the device on the plug all the components burned again i had tested before and i had not shunts
i dont understand whats happen wrong
more particular on the schematic q11p01 mosfet q11p02 tranzistor
three paralel resistors had burned q11p07 zener shunt q11p08 open
when i changed all these shunts q11po7 mosfet and tranzistors
maby the transformer has problem on your opinion or something on...08-19-2023, 01:27 PM - Loading...
